BTW, in the setup guide it says "Furthermore, you might want to disable 'Create Alert list images when triggered' ".
But in the newest BI, I don't see this option?
Check under the trigger menu.
Just has the capture alert list image, not Create alert list images when triggered". Seems to be a different setting per this post:
2.5 Store alert images in 'Input Path'
now go to Record, check 'JPEG snapshot each (mm:ss)', select the folder you created in step 2.1, check the box 'Only when triggered' and set the interval to p.e. 0:05.0 (one image every 5 second). Furthermore, you might want to disable 'Create Alert list images when triggered', because otherwise alot of false-alarm images (remember we set the motion detection to be very sensitive) will be stored in your alerts folder.
Now go to 'Trigger', check 'Capture an alert list image' and set the Break time 'End trigger unless retriggered' to p.e. 4s,
Hi... using this tools since two months and I have a recurrent problem... Dont know why it stop reading img files generated by blueiris so I dont get any motion alert. Restarting the tool solves the problem but it happens every two days recurrently... Not any msg in the log... Its extrange because blue iris continue generating the images when motion is detected, deepstack is running fine... Its like this tool stop reading new files without any reason.
Using hp i5 7500t with 8gb ram w10pro and 500gb sata disk.
Thinking create a service that close and reopen the app every night... but its not the desireable solution...
Thanks in advance by any help
How big is the folder that holds the images? I have mine set to 1Gb, any larger and as the folder space gets used it becomes too slow to manage the content.
Also was hoping that the latest .20 update may have JPEGS being captured at the main stream resolution but still at the sub stream resPity this as with me having to remove the substream config from the clone BI no longer views the clone as a true clone and therefore starts to pull separate streams for all the clones I use for AI.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at WindowsFormsApp2.Shell.UpdateTimeline()
at WindowsFormsApp2.Shell.tabControl1_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.TabControl.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.TabControl.WmSelChange()
at System.Windows.Forms.TabControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Did you add the tag name of that phone?Okay, have set up all "AICams" as clones, and I am getting an email only for "human" or vehicle triggers. So far so good.
One remaining issue, the alerts are showing up in my BI android app. But I am not getting any notification from it whereas I was before. I.e., the alert is there when I open the app, but the notification won't work to notify me of it.
I have checked my phone to ensure that the BlueIris app has notifications turned on in the Android settings, and have set up each of the "AI" cameras with push notifications on alert as per the below. Anything else I'm missing?
Okay, so now that I have that weird issue behind me, what I'd like to do is set things so that I am only getting an email from BI and a notification on my BI app when a person (or vehicle on my driveway) triggers an event. I.e., not when my trees blow, or oncoming headlights flash on my driveway as I am getting a ton of false positives. What should I be doing in BI vs the AITool to allow for this since this tool isn't like Sentry where with Sentry I only get a notification when a person is identified?
What cameras are you using?Find them quite similar. The nice thing about deep stack/AI Tools is that you can also choose vehicles, animals, etc. Whereas Sentry is solely for human detection right now.
The fact that AITools is free...is the icing on the cake.
How is the BI w/deep stack vs BI w/sentry with false positives?
