Hi, I've found the same so I record the clips in BI and use the AITool to send me telegram notifications. The tool is great in the day but I've found deepstack a bit lacking at night, even with good IR lights.Hello Folks,
I am new in AI management for IP surveillance CAMs. Got runnning flawlessly AI tools with DeepStack and BI5.
But I'm having some false alerts at night with IR LEDs ON, on AI tools which are clear to be an actual alert.
As I am still testing everything I have confidence at 0-100% and Car and person detection.
Do I have any solution? Is there any other AI server better than Deepstack?
Thank you guys!!
It sounds like Deepstack needs to be activated. Have you tried browsing to (or 81) and activating Deepstack?Hi
Win10
deepstack show STOP SERVER
Log AItool 1.63:
[08.06.2020, 14:17:24]: Starting analysis of C:\AIinput/AI_W1.20200608_141724362.jpg
[08.06.2020, 14:17:24]: (1/6) uploading image to DeepQuestAI Server ...
[08.06.2020, 14:17:25]: (2/6) Waiting for results ...
[08.06.2020, 14:17:25]: (3a/6) Deserializing results ...
[08.06.2020, 14:17:25]: (3b/6) Processing results:
[08.06.2020, 14:17:25]: ERROR: Processing the image C:\AIinput/AI_W1.20200608_141724362.jpg failed. Failure in AI Tool processing the image.
tried to repair with:
AItool1.65 or 1.63
install C++,
restart machine
run aitool as admin
depstack port 80 and 81
Noticed posible error:
in IE can not Access localhost:81 (in deepstack window i have message: Visit localhost to activate Deepstack) ?
Any suggestion what else to try?
LP, W
Suddenly Aitool gives me this error... Have been running fine for weeks.
Did anyone figure it out?
Over 2 TB free on my server. can't imagine what else could be using that file?Disk space? anything have that file open?
Perhaps the file is corrupt or possibly too big.Over 2 TB free on my server. can't imagine what else could be using that file?
The new variable is &trigger&memo=text which allows up to 35 characters to be stored. This is great because it allows you to specify keywords ie “person” or “dog” or the actual relevant triggers?
Therefrore is it possible if you could add some variables into the program so we can do %trigger% Or similiar which will allow us to store the exact relevant trigger word? Great for high level overviews!
/admin?camera=x&trigger that use the &memo=text HTTP query parameter.&memo=my%20text.
@GentlePumpkin is there anyway you could release a new version which supports the &memo=text variable?
That sound really cool! Does the memo text show up in UI3 aswell? You can build the latest version from Github, it includes the following placeholders you can insert into the trigger url:
[detection]
[position]
[camera]
[confidence]
[detections] (all detected objects separated by comma)
[confidences] (all confidences separated by comma in the same oder as above)
So this might work: /admin?camera=x&trigger&memo=[detection]%20([confidence])
It's not yet release because I had no time to test it sufficiently and I don't want many people having problems after updating. And it includes some changes towards flagging relevant alerts (so that duplicate cams are no longer neccessary).
That would generate some odd results.. would give you for example 'person,car,dog 0.999999999,0.543242,0.123214'
