Futaba
Pulling my weight
- Nov 13, 2015
- 227
- 168
How much Memory does your 670 have?
My 670 has 4GB memory.
 maybe you are right @Village Guy but I have reading about this issue, and maybe is about the FileSystemWatcher I will try to find a solution testing some change to the InternatBufferChange or something like that !!! Thank you anyway !!!
Rather than posting error reports can you state what is working and what is not. It's not clear to me if telegram is your only issue.Hello everyone, sadly stuck in the same problem (file Wacher), any other help will be appreciated before leaving AI Tools.....Regards !!
You say everything is working fine without telegram. Have You confirmed that by checking the error log after some time running without telegram?Sure @Village Guy , this is the point, just telegram is not working (alerts snapshot), everything else is working fine.
To understand the real problem I suggest taking these baby steps.
1. Disable telegram and Pushover (You have Pushover enabled) test some cameras and confirm it works for say 10 minutes without logging any errors.
2. If point 1. passes without error. Disable all your cameras from triggering and enable telegram. Assuming still no errors, manually trigger a camera that will recognise an image and trigger telegram. Do you get any errors?
We need to understand if filewatcher is simply becoming overloaded or If there is another issue at play.
BTW BI allows both short and long name to be edited!
