CrazieBird
								Hello. This program have been working wonderfully for me but there is one big issue: It runs on Windows.The latest version v0.5 can send alert images to Telegram and call multiple trigger urls (p.e. home automation server, blue iris, etc).
You could upgrade your network.... I run a Netgate SG-4680-1U pfSense router. It allows me to make complex firewall rules and has OpenVPN built in. I have firewall rules that only allow my Windows machine running BlueIris to connect to what I whitelist. I never have Windows issues that way. Windows updates can be evil. I remote in over LAN using OpenVPN and the built in Windows Remote Desktop protocol. Also you need to set up Windows 10 like a server. Never sleep, restart after power loss, no sign in, ect... I've been mining Ethereum (cryptocurrency) on Windows 10 with rigs running between 8-13 GPU's for 4 years straight 24/7/365 (if you think Windows is unstable try running a machine with 13 GPU's overclocked to their limit on as little power as possible) and I could literally count the times on my hands I've had Windows specific issues.Hello. This program have been working wonderfully for me but there is one big issue: It runs on Windows.
I bought a PC only to run Blue Iris with this AI program with all the recommended technical requirements, but Windows is too unstable. Over these 3 months that I've been testing it, the most time that spent without freezing, crashing or stop working, is 2-3 weeks.
For example now I'm hundreds of kilometers from my house and I try to login by teamviewer and Windows don't want to show me the login, so I can't enter my pin code or do anything, but the program is working.
First time with this issue, but the point is there is always some problem and I can't just leave it alone and trust that I'll work.
So I was wondering how could I solve this, do you guys have some ideas?
I was thinking that maybe I could run this on Linux and use something like Home Assistant or something that can monitor cameras and save pictures into a folder when detects motion. Has anyone done this?
Thanks in advance
This is 100 percent user error. Windows is VERY stable. I have over 20 blue iris systems with zero issues that run many months until I decided to upgrade. I run and support many more windows pc. None of these issues. Perform a clean install using the MS media creation tool and dont install crap.I bought a PC only to run Blue Iris with this AI program with all the recommended technical requirements, but Windows is too unstable. Over these 3 months that I've been testing it, the most time that spent without freezing, crashing or stop working, is 2-3 weeks.
I did some experimentation on this a few weeks ago. If I remember correctly, if you make any changes to the video settings after the clone is created, it doesn't see it as a clone anymore. I never could get it to stick, so I gave upNo one has an idea why the clone cameras don't work properly? I don't see that these are clone cameras anymore.
I am using 5 clone cameras and have never experienced any problems! I chose to use clone cameras as I did not want to record continously.No one has an idea why the clone cameras don't work properly? I don't see that these are clone cameras anymore.
Okay and your Solution ?I did some experimentation on this a few weeks ago. If I remember correctly, if you make any changes to the video settings after the clone is created, it doesn't see it as a clone anymore. I never could get it to stick, so I gave up
Sent from my Pixel 3 using Tapatalk
Okay same solution my clone camers changed to normal camerasI have copies of my cameras, they just aren't truly clones. CPU usage is a little higher, but not enough to worry about
Is it possible you're getting memory leaks from using a incompatible intel driver that's crashing Windows? I had that issue with my machine when I first installed Blue Iris and used Quick Sync decoding. There is info in the Wiki about it.
There is also a watchdog for BI in Blue Iris Tools you could use. But it shouldn't be necessary, if you need it your doing something wrong.
Is there a way to ignore certain types of objects per camera? i.e. my driveway camera has two cars (one is being detected as car and the other is truck), they are always in different locations so i cant mask the whole area. What I am trying to do is, if it detects a truck or car on the driveway camera at all and no other objects, it should be a 'false alert' not 'irrelevant'.
I want it to be false because are reported on this page sometimes people are detected as 'dogs' or 'bear' etc. so i want to manually review irrelevant alerts to see if it is actually objects of interest. For me personally, I know cars and trucks on my driveway camera are falseEdit: Sorry just realised you want it to be a false alert. What are you hoping to achieve by doing that?
Here is a screenshot: ScreenshotI seem to be getting (often) 101 actions queued .... and then subsequent errors saying the queue is full... is there a way to manually force the queue to execute? nothing seems to be happening?
I have this working, however now I've got a few thousand spam alerts that are just jpgs. If I turn OFF "Capture an Alert List Image", it should still take the jpeg snapshot trigger pic, just not add it to the alerts, right?
View attachment 75162 View attachment 75163
