The code in Michigan is the installed microwave must be on a dedicated circuit. If your DB transformer and microwave are on the same circuit, the voltage drop caused by the high current drain microwave could be upsetting your DB.
Separate circuit plus the DB Transformer is on a dedicated circuit w/ UPS with line conditioning and dual 100ah group 27 batteries.
24V 20VAI get notifications on my phone. I’m using the Hik-Connect app. I also have the Uniden app installed but have all notifications turned off on it and don’t use it. What’s the V/A rating of your transformer?
Thanks Tim... if I use the Hik app do I have to reset the camera back up where I scan the barcode, connect to wifi etc. or can I just add the device somehow? I have connected to the IP of the cam. Some of the settings won't save my changes, I get "parameter error".Your power supply sounds sufficient. Try the hik-connect app. Also, log into the camera’s IP on your desktop and play with some of the setting via the GUI.
That worked. I'll see how it compares to the Uniden One app. By the way, where do I set the motion detection settings? I can't find them in the app. Thanks again!I think you should be able to log into the Hik-connect app with the same credentials as the uniden. They use the same servers. I don’t know about your parameter errors.
Got it, thanks! IR just kicked in here... reflection is not great.Three dots above “my device”.
Alarm notification
Draw motion detection area
It’s all in there. However, draw boxes are smaller in the web GUI.
Went out there and cleaned it. Now the IR won't turn back on for some reason.U really have to keep the lens clean. I use a microfiber eyeglass cloth about twice a week depending on wind/rain and my sprinkler overspray.
It's been almost 15 minutes, so we'll see. ThanksGive it time...
30 minutes now, wish there was a manual way to turn it on/off in the GUI.It's been almost 15 minutes, so we'll see. Thanks
