Chadsturgill
Tech support told me that this happens when you connect Blue Iris to it. Did you by chance do that? Rebooting the camera always fixed it for me.
 anyone has problem with 180728 getting motion alert but can't play the recorded video? it worked fine on 171219 but as soon as I update it to 180728 it stop working. I was attributing this to wifi signal problem before, but i have since resolved the wifi signal issue. This is with both the new RCA security and the Hikconnect app
If it started after the upgrade you probably need to factory default it. That will clear out any old config from the 171219 firmware. Let us know how it goes.
Thanks - no I don't have anything else connected to it currently. Will try the reboot today - I have to remove the cover right?
Is anyone else having issues with their doorbell? I am on a DB1 from Uniden and so far this week, on two separate occasions, the doorbell is acting weird.
1st occasion, I magically got a package at my front door, without the doorbell recording activity of a person dropping the package.
2nd occasion, the thumbnail of the video playback shows the mailman throwing the package, but when I playback the actual video, it does not show him do that, but instead shows him walking away already. So it did not record him entering the field, throwing the package, and walking away.
I am currently on version v1.4.62 build 171225
Nope, I did not.Did you try to view the video as soon as you for the notification? I think that sometime cause gap in the recording
How's the wifi signal? I found the weak WiFi cause a lot of issue with borderline signal that may work well normally, but any additional event like motion that add to the strain causes hic up. Using the extended antenna really helped a lotNope, I did not.
Seems like this doorbell is nice for the most part, but clearly it has quirks which I am not sure if it is worth it over the Ring Pro which I replaced it with. :-/
Well I have a Ubiquiti setup. I have a UniFi AP Pro upstairs and I have a UniFi AP Pro downtairs, and the doorbell is no more than 5 feet from the one upstairs if I were to take a measurer and measure the distance direct. Granted there is a brick wall separating it, but the Ring Pro had no issues connecting and the Ring Floodlight doesnt have an issue either, considering it is further away distance wise from the AP Pro.
No, you can reboot that on the device's web portal
What if I forgot the password :-o
I’m not sure where the leak is coming from. I may take out the board. Load it with toilet paper and soak it with dyed water to see where the Leak actually is located.
I took the thing apart and I'm pretty sure the dome itself doesn't seal off correctly. IP54? Don't think so..
Can anyone tell the difference between the DS-KB6003-WIP and the DS-KB6403-WIP. Is the 6403 just a newer hardware revision of the same product?
