Same thing, cannot login to the laview app today. I never used any others so definitely something going on
Just a follow up to this for a fix just in case anyone stumbles upon this. I run a Dahua NVR with this doorbell and was having trouble with the ONVIF protocol when adding the doorbell to the NVR. The video feed would drop out randomly (not due to wifi) and the motion detection on the doorbell settings would randomly turn off after enabling it through either the web gui or the phone app. To fix this, I removed the doorbell from the Dahua NVR and added it back with the Customized protocol linked directly to the RTSP streams. The NVR now records the video streams 24/7 with no dropouts. The motion detection was enabled via the web gui and the phone app sends me notifications for motion alerts and clips. Since changing it the motion detection has not turned off randomly. I'm chalking this one up to incompatibilities in the ONVIF interpretation between competing companies.
I've been able to use the Guarding Vision app instead of the laview one. Others are also reporting being able to login to one app, but not others. It's not an ideal solution but it at least gives you access to the doorbell features while they finish their "maintenance"Well another day and still not able to login. Surprised more people are not pissed about this. I know we have it recording to blue iris, but the whole point is to be able to answer when someone rings the doorbell. Midas-well just put a camera up at this point.
I've been able to use the Guarding Vision app instead of the laview one. Others are also reporting being able to login to one app, but not others. It's not an ideal solution but it at least gives you access to the doorbell features while they finish their "maintenance"![]()
what firmware version of your laview cam has? my laview came with v1.4.62 build 171219. the laview ios app i am using is v3.3.0.180324. i have no problem loggin into laview app and use it.Well that only helps users that used another app before this "maintenance" the wife and I solely used the laview app since we got the doorbell so have no other option other than creating a new account.
what do you guys use to set the motion detection area on your doorbells? ivms-4200? what else can be used for that? any mobile apps that will do that?
the mobile app? do you mind sharing how this is done? for the life of me I can't figure this outHik-Connect will let you set motion zones.
