kevyc
- Jun 10, 2017
- 3
- 1
That's what mine sounds like without a power booster.
I do have the Ring power board installed in my chime. Unfortunately, I still get the same clicking noises with and without it.
Those are from the IR I believe. I have the same thing in mine.Heres a screen grab of mine.
When first fitted there was condensation on the inside of the dome.
Are the marks i see at night time from the ir, or from when the condensation was there?
yup IR, try cleaning the dome lens with lens wipe or glass cleaner. it helps cut it downThose are from the IR I believe. I have the same thing in mine.
Cleaned lens and turned off the ir
Now looks a lot better!
Could anyone link me to a relay I could use instead of a chime? When I press the button I want the relay either to go off or on - so I can signal my alarm which controls my door chime amongst a bunch of other things - I would be sooooo greatful for any help.
Thanks
Stuart
For some reason when i adjust the cameras settings on my hikvision nvr, save them, then return them to original settings the ir has been disabled.How did you disable IR?
Has anyone had a problem where the doorbell rings intermittently? I thought it might happen when it loses the network connection, but can't say for sure. I really like this camera, buy this might be a deal breaker.
Thanks for your response. Is there any way to resolve that, if it does turn out to be the case?Not having internet connection will not cause that. Check your voltage, sounds like your transformer may be on the hairy edge of the voltage requirements of the cam.
load up the app (hik-connect or whichever re-badge you are using) load up the live stream screen, click the triple dot in the upper corner (android, not sure about IOS... however you get menu) and click setting. Device version should be at the bottomThis sounds like what I'm experiencing in addition to the chime. How do I check the firmware version?
