If they made the 5442 4MP cameras in the Z12 focal length, I think that would be the new king for a lot of us LOL.  But I like the person to be as large as possible on the screen, so I favor a 2MP with more optical zoom than a 4MP with less optical zoom.
For objects up close, the 4K/X is an incredible performer with low light capabilities, but it does need some light.  If you are ok with the white LEDs on during the night, it is a winner, but I suspect you prefer more dark and would run infrared with B/W.
But if the object is in the sweet spot distance for a 2MP on the 1/2.8" sensor, it is hard to beat for the dollar.
If you want to see things far away, you need optical zoom, digital zoom only works in the movies and TV...And the optical zoom is done real time - for a varifocal it is a set it and forget it. You cannot go to recorded video and optically zoom in later, at that point it is digital zoom, and the sensors on these cameras are so small which is why digital zoom doesn't work very well after the fact.
I'd recommend you consider a
Blue Iris/computer combo as an NVR. Keep in mind an NVR is simply a stripped down computer after all... And this would allow you the flexibility to mix camera brands.
You don't need to buy components and build one, or buy a new computer either.
When I was looking at replacing an existing NVR, once I realized that not all NVRs are created equal (the bandwidth is can process is a huge limiting factor), and once I priced out a good one, it was cheaper to buy a refurbished computer than an NVR.
Many of us buy refurbished computers that are business class computers that have come off lease. The one I bought I kid you not I could not tell that it was a refurbished unit - not a speck of dust or dents or scratches on it. It appeared to me like everything was replaced and I would assume just the motherboard with the intel processor is what was from the original unit. I went with the lowest end processor on the
WIKI list as it was the cheapest and it runs my system fine. Could probably get going for $200 or so. A real NVR will cost more than that.
A member here a couple months ago found a refurbished 4th generation for less than $150USD that came with Win10 PRO, 16GB RAM, and a 1TB drive. You won't find a capable NVR cheaper than that...
Blue Iris has a demo, so try it out on an existing computer and see if you like it.
There is a big
Blue Iris or NVR debate here LOL. Some people love
Blue Iris and think NVRs are clunky and hard to use and others think
Blue Iris is clunky and hard to use. I have done both and prefer
Blue Iris. As with everything YMMV...
And you can disable Windows updates and set up the computer to automatically restart in a power failure, and then you have a more powerful NVR with a nice mobile viewing interface.  I have found the power consumption to be comparable to an NVR and even less in some instances.
Blue Iris is great and works with probably more camera brands than most VMS programs, but there are brands that don't work well or not at all - Rings, Arlos, Nest, Some Zmodo cams use proprietary systems and cannot be used with
Blue Iris, and for a lot of people Reolink doesn't work well either. But we would recommend staying away from those brands even if you go the NVR route with one of those brands...
