tangent
- May 12, 2016
- 4,641
- 3,997
I haven't had the best track record with Siemens AFCIs. Lightning and other power spikes seem to have killed a couple of mine.Yeah Those Arc fault breakers are junk. They get very hot compared to traditional GFI breakers or regular ones. I've had to replace a ton of them between 2019- current. My parents house had Seimens breakers which they had a recall on I believe.
I personally feel they should have left ARC in the bedrooms instead of expanding the code through the house.
I thought Eaton's AFCIs had a decent reputation. BR or CH?Had to replace our Eaton ARC Breakers; they would trip way too easily, actually one circuit, our Master Bathroom was tripping all the time, it was a pain getting up at night with no lights. Ended up unplugging everything off the circuit, replaced all the plugs/switches, still had false trips. I contacted an Electrical Supply and they said the first generation of most all brands of ARC breakers, not just Eaton, were designed bad, I bought new Eaton ARC breakers and never had any problems after that. Should of replaced in the first place but since the others only tripped maybe once or twice a year I focused on the Master Bathroom tripping monthly.
If I were choosing right now, I'd probably go Square D. Just a debate between QO and Homeline.
