I purchased an Apple Watch and for the life of me can’t figure out how to display the URL on it. Any suggestions?
 Trade it for a Pixel watch.I purchased an Apple Watch and for the life of me can’t figure out how to display the URL on it. Any suggestions?
Yes.if I'm not using a custom sound, should I just delete --form-string "sound=%999" (i didn't define any 999 in registry)
If (much later than the alert event) you want to view the image via the Pushover notification's 'Hi-Res' hyperlink, it's best to enable 'Burn label mark-up on images' OR add 'Hi-res JPEG files' to the alert list (moved to the Alerts tab in v5.8.0).Within each camera configuration;
- Deepstack - Do I need to enable burn label mark-up on images
 - Within Trigger - Aadd to alerts list - what option within there do I need to choose?
The macros work only from Blue Iris Actions. Replace them with actual values.Testing at command prompt also failing
C:\Users\BIuser>curl -s --form-string "token=%996" --form-string "user=%997" --form-string "message=<b>&CAM</b> &MEMO" -F "attachment=@C:\BlueIris\Alerts\20240519_160000039.front.13701655.5123-7.15785.16770.jpg" --form-string "device="%998"
{"token":"invalid","errors":["application token is invalid, see Pushover: API"],"status":0,"request":"babeeffd-e180-439d-a18f-bbce0f7d8b9f"}
C:\Users\BIuser>
Do you see the macros and values when using regedit?I suspect something is wrongly configured in my registry
Yes they are there’s I posted a screenshot in my earlier threadDo you see the macros and values when using regedit?
Navigate to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Perspective Software\Blue Iris\Macros
Can you explain further? I don’t know what are actions, I am simply using the syntax in the camer alerts actions pageThe macros work only from Blue Iris Actions. Replace them with actual values.
That's it... the 'On alert' Action set from the Alert tabCan you explain further? I don’t know what are actions, I am simply using the syntax in the camer alerts actions page
I see it now.Yes they are there’s I posted a screenshot in my earlier thread
Have you tried the these suggestions in the Debugging section in post #1?So any idea how do I get macros to work? Thx
2. Did the msg.exe popup show the expected values for the macros?1) Blue iris service - running with a user(admin) account
2) Did msg.exe as a trigger and get a dialog box both with manual trigger from blue iris console and the mobile app
3) I didn't try this yet - Need help setting up BI5 text alerts.
Am I supposed to use my actual API token & user key or simply the macros for creating the syntax for logging?
curl.exe <pasted line here>
