On Friday I put a tester on the wire and continuity was good, changed RJ45 at camera just to make a tighter connection.
Friday night it shut off again, same-ish time while tracking vehicle in the dark.
Today I performed a factory reset from the web interface (Edge in IE mode) and within the first 15 minutes after setting IVS rule a vehicle pulled in and was being tracked and crashed the camera per the usual except it was in the middle of the day!
I put an inline tester on and watched the power consumption as it tracked and moved on both axis while zooming and it never exceeded 13 Watts.  Starting to circle back to my original assumption that this firmware is suspect.
I am planning to switch to a different port on the switch tonight.
Is there anything else I can try?
I performed the factory reset through web interface, is there a difference with performing it from the camera side mechanical button?
Is there a way to roll back to the factory firmware?
