GTX 1660, i5 4th gen, 16GB RAM, M2 SSD, WD Purple ProOut of curiosity are you using hardware acceleration and if so what flavor?
But how do you have HA set in BI?GTX 1660, i5 4th gen, 16GB RAM, M2 SSD, WD Purple Pro![]()
Intel + VPP at the moment, I did experiment running NVDEC for a while but was getting mixed results and CPU took a hammering.But how do you have HA set in BI?
Thanks, I will give it a go and report backWe have seen some goofy things with HA in recent updates so maybe try not running HA and see if that fixes it. With the substreams, HA isn't as critical as before
- currently running version 5.5.2.4 and tonight the camera is still working after schedule change
spoke too soon, tonight the same camera went offline for recording at the schedule change, shows in the live view substream, stills viewable from events but no actual video footage on playback. How odd that it worked yesterday though after many days of failure.Driving me a bit mad at the moment, if it does turn out that a full reinstall is required then I might use the opportunity to move Blue Iris to my other computer...the one I built over a year ago for Blue IrisUgh - I hate when we see someone have an issue that nobody else has and we can find no reason why it is happening.
I don't think you have tried uninstalling BI and redoing Windows yet and starting from scratch? Kind of a last resort thing, but you are slowing heading to that path it appears.
