Parley
It's always the best option to solder the connections.
I agree, but I am trying to figure out how to twist ends of the two parallel wires which are right next to each other. That makes for a solid mechanical connection. One set is easy enough to do and then tape it up. If they are long enough maybe there is enough room to twist the 2nd set of wires for a good mechanical connection and then solder them up. Then put the heat shrink over the whole area.
