cryptelli
Pulling my weight
Here are a couple install pics. Finish up tonight installing the 5231 dome inside, and the PIR's on the outside.
Looks very clean and professional, great work! I see you used the rubber boot that someone posted about
Yeah, great lead on the firewall boot from the forum. It's ~$10, but I will gladly pay a little more for convenience. All the Dahua mounting solutions are clean and top notch.Looks very clean and professional, great work! I see you used the rubber boot that someone posted about.
Have you read the thread especially the last few pages?. I have tried WDR/2D&3D at different settings also the FPS on many many occasions in default middle/low/high.
I live in Owen Street and I would say that street lighting is ample for me to have a camera in colour. All my other cams where run in colour no problems so the starlight should be much better but opposite it's much worse.
As posted many times before by myself I didn't buy the camera thinking I was going to have to use it in B&W, mode at night ,I purchased the Starlight series as they are "suppose" to be the best for colour at night time.
Not sure why you stated I am refusing to listen I'm all ears but please read what's been said first before posting.
@nayr, do you have a sample video from your B&W footage that you can share? I experienced not such good results as you describe with B&W and moving targets. I only get bright shiny eyes and extremely overexposed license plates when people or cars pass by. Also it takes a long time for the camera to focus in B&W, so that the moving object is already out of sight before the focus is right. I will post a video later tonight when i can get some B&W IR footage.
Tried factory default many times and you will have to trust me that the lens is perfect no marks or fingerprints.
Noted and thanks and just a reminder I have to do all this via third party software or in the Web Interface as I can not get the camera working in Dahua's own software for some strange reason which is a concern in its self.
My other 2 Dahua camera's Purchased from Andy have never given me any trouble whatsoever and work a treat in SmartPSS.
Andy is going to send me a different firmware to try later.
Does this look right. This is how I have it set up, and it is not returning to Preset 1 if on any other preset.It's a time schedule in the WebUI of the camera. You can set the idle time when it returns to whatever preset you like. I'm not in front but have it working for this setup:
Two PIR's at the corners of the pole barn connected to the alarm inputs on the NVR. If they trip, the camera swings to the preset that faces the corner that detected motion. After there is no motion for 30 seconds, it times out and returns to the Driveway preset and tracks motion in an intrusion box.
It's there, just don't have it in front of me.
SD
PTZ looks really good there.Set this camera to B&W and my other Dahua IPC-HFW4830E-S to do a bit of a comparison.
The reason I purchased the Dahua IPC-HFW4830E-S was Daytime footage but being honest I'm happy with it's night time performance also.
My PC is the very latest Kabylake K series i5 CPU 32GB ddr4 memory Samsung Pro .m2 SSD Drive and 4GB Graphics Card so plenty enough to run 3 camera's and usually around 25% Cpu load depending on FPS and coding etc and including daily constant use.
Powered Via a dedicated POE Injector.
Beingaware - you are welcome to remote in via teamviewer if you think you can resolve my problem.
It's a 4k/8mp cam with a starvis sensor, it is a nice looking image better than I'd expect for the light level actually on an 8mp cam. But fine detail is probably sharper in the ptz image (which is zoomed in more than the 4k)Is it me or does your IP Camera seem sharper (or perhaps cleaner) than your PTZ ?
Checked over his config.
Found the reason why his HTTP and Smart PSS kept dying.
UPNP was on, so RSTP, HTTP etc was getting hit hard WAN side.
Moment it was turned off, camera started to behave again.
Adjusted his light configuration settings but will need some night movement to test so we will find out in 8-12 hours time I guess.![]()
That looks correct. After moving it anywhere but Preset 1, two minutes of idle time will return it to Preset 1.Does this look right. This is how I have it set up, and it is not returning to Preset 1 if on any other preset.
When I am off of any preset, after 2 minutes, it returns to preset 1. When I go to any other preset, it will not go back to preset 1 after 2 minutes. My SD-49225T-HN goes back to the idle position (which is also preset 1) after the set time. I am thinking of doing a factory reset and trying again, as I am the only one that seems to be having this issue.That looks correct. After moving it anywhere but Preset 1, two minutes of idle time will return it to Preset 1.
Have you tested it?
SD
Doesn't work for me as well.
What I am looking to do, is have preset 1 be the Home. If something triggers the camera to another preset, being an alarm activation, another camera, etc, and there is no other trigger for the set time, then it will go back to preset 1. As I stated, my SD49225T-HN does that and works as intended.I experience the same behaviour, but if you think about the term "idle motion" I would assume it means after someone has manually adjusted it from the preset. If you position it on a preset and it's left alone there is no idle motion because you set it on a preset.
Not sure if that makes sense but in my estimation it's working perfectly fine.
