Gosh, I'm missing this. Sorry. I know how to set up multiple IVS rules in the camera with one using human and vehicle and a completely different on using animal only. If they're both active then if the animal only rule triggers overnight, how do I tell BI not to alert on that one?No, you set up an IVS rule for animals only and don't have that one alert you and setup another IVS rule for person and vehicle and have it alert on that IVS rule.
Thanks so much, I'll give this a try!Either keep track of what each IVS rule is named (IVS-1, IVS-2, etc.) or rename each rule in the camera GUI.
Then simply hit the + sign and in the Contains block put in the name of the IVS rule (IVS-1 or if you renamed it something else like animal) and then in the memo you put down what it is for.
As they populate, they will show up in the Listen for:
Then you go into the alerts tab and the stuff you put in the Memo field can be used for the required AI for which ones you want alerts for:
Use the "New zones/sources only (additive)" option if you are going to have several IVS rules being used in one camera and want to be able to do something with each rule separately.
This is super helpful info! Thanks!Either keep track of what each IVS rule is named (IVS-1, IVS-2, etc.) or rename each rule in the camera GUI.
etc
etc
another few days and animals are being triggered perfectly (the deer have cooperated by visiting every day) , and I've had no false triggers from weather/spiders/sun etc.. Looking very good!@bigredfish Is this true with animal detection enabled on this cam firmware?
Mine triggered on a bird on the ground. It would be good to find out a list of animals it detects.Does it trigger for birds? Snakes?
Ditto on the comparison ... and to be clear, the S3 version of the 5442/54IR - not the "original"
I don't think there is an "S3 upgrade" on the 4KT - right?
If I were designing the algorithm there wouldn't be a list available. I'd approach it differently than CPAI does, where it compares the image against zillions of training images. I'd instead look to identify a few general attributes, like a head, body, and legs, moving in unison, only after the object has been discarded by human detection. If I understand CPAI correctly, it won't for instance declare a rock chuck to be an animal if it hasn't been trained with rock chuck images. Yet human intelligence would easily identify it as an animal without ever having seen one. Snakes and birds in flight would need different algorithms.Mine triggered on a bird on the ground. It would be good to find out a list of animals it detects.
Anyone here really compared the quality of detection for people and vehicles between the onboard AI from the 54IR and CPAI? I'm really looking forward to not using CPAI. Testing is going well with the camera IVS. I'm trying to figure out if just drawing an intrusion box set for appears/cross for the FOV, would that be good enough? Do I really need that and tripwires? Seems like the fewer IVS rules the better. ThanksIf I were designing the algorithm there wouldn't be a list available. I'd approach it differently than CPAI does, where it compares the image against zillions of training images. I'd instead look to identify a few general attributes, like a head, body, and legs, moving in unison, only after the object has been discarded by human detection. If I understand CPAI correctly, it won't for instance declare a rock chuck to be an animal if it hasn't been trained with rock chuck images. Yet human intelligence would easily identify it as an animal without ever having seen one. Snakes and birds in flight would need different algorithms.
In limited testing with a few s3 5442 cams running the "animal beta" , I'm getting similar triggering using only IVS (setting both tripwires and intrusion... figuring more is better) from BI Motion combined with CPAI (IPCam-combined, 2.6.5 CPAI). Both seem to trigger very well on Cars, People, Deer, Opossum, and once I dialed in the size limits in IVS, no squirrels and chipmunks. Right now it's a tie, but of course using IVS only means not needing to run motion and CPAI. Need some more time to see how any false triggering will appear... I do use separate IR lights so less chance of false triggers from spiders and rain. CPAI would occasionally trigger on a cat or other small animal I wasn't looking for, and I expect IVS will do the same. But over the last few days, any odd trigger from a shadow have all been from CPAI, not IVS, so there's that.Anyone here really compared the quality of detection for people and vehicles between the onboard AI from the 54IR and CPAI? I'm really looking forward to not using CPAI. Testing is going well with the camera IVS. I'm trying to figure out if just drawing an intrusion box set for appears/cross for the FOV, would that be good enough? Do I really need that and tripwires? Seems like the fewer IVS rules the better. Thanks
So if my IVS rules have human, vehicle and animal as targets, I'll get critical alerts overnight for animals which I don't want.
I’d really like to be able to have the AI provide critical alerts for people and cars (we don’t get that many) yet still record lower level animal alerts so I can see them in the morning or at my leisure. We get all kinds (bears, moose, deer, fox, coyote and yes plenty of rogue dogs) so I want to know what’s going on before I throw the dog outside only to have her running for dear life. I’ll have to try the alert rules wittaj posted above and see if I can get them to work.
Yes, your instructions above are working great for me! Much appreciated. On-board AI is faster with notifications as well compared to CPAI. I have an Amcrest doorbell camera that doesn't have IVS rules, that's the only camera left of my 16 that will still be using CPAI to confirm person alerts.You can do that as I outlined.
We had several marters last night. Neither 5442 picked them up, the 5231 did.Just installed the firmware on 2 camera's. I can verify it against animal detection on one since it right above a 5231. The other is at the back.
Night here has begun so that's when I most see animals so now we'll wait...
