Review- EmpireTech IPC-T54IR-ZE-S3 4mp Varifocal Turret
So, what Dahua NVR for this smart AI cam (IPC-T54IR-ZE-S3)? I see the cam has SMD 3.0 but the 8-Channel AI NVR that Andy sells (NV41AI-8P-4KH) only supports SMD+. I've been told that these new cameras with the AI smarts need the NVR to play along so I assume that this NVR would not be optimal on this issue alone. Can anyone chime in on this one?
EmpireTech NVR 4-EI Series Smart AI 8 Channel Compact 1U 8PoE 1HDD Wiz Network Video Recorder, Face Detection and Recognition,Perimeter Protection,SMD Plus,NV41AI-8P-4KH
What's the optimal match for the IPC-T54IR-ZE-S3?
Thanks,
R
Most of us here don't use SMD. AI with IVS is far superior.
The 4 series is the lower end and with any number of cameras you will run into to bottlenecks quickly.
The 5 series is the one you want with the 5 series cameras.
One problem, Andy does not list model numbers on his web site....
So, can you recommend a specific model or two? I would like to know the international and AndyNumbers as well. I wish we could have just one model number and one place to lookup... This always seems like a Columbo investigation. :)
Thanks,
R
Reactions: Valiant
What part of the NVR would incur the bottleneck? Is there something in particular to look at on the specifications that indicate this higher capacity on the 5 series?
Thanks,
R
Thanks,
R
Yeah up until a year or so ago, Andy could use the same numbers as Dahua, but they made a change on resellers and he had to rename.
From his website it will be the Wiz and Pro series.
Yep the 52xx series.
Bandwidth is the big factor. Some NVRs are rated for 40 or 80Mbps and that is just way too low.
As MP increases, even the 160Mbps are showing to not be beefy enough.
Reactions: juliand and MacFun
Still have trouble finding a given international number or series on Andy's web site.... he often does not use model numbers! "NVR16CH-16P-2AI" is not useful. I cannot see what series it is..... there must be a better way. Why can't we have a cross reference chart? So I need a model number to look for in the 5 series for 8 and 16 channel.... no POE.... but want all of the smarts and the muscle available at the is product level....
R
Somewhere in the forum is the secret translator LOL.
On Amazon, it will show the 5 or 4 series
On his website, chose the Wiz and Pro
Check directly with Andy but I dont think there is any compatibility issue between SMD/SMD+ and the recorder.
FWIW, I would go with the next step up and the 5xxx series. Much fewer limitations and not as underpowered
Instead of placing multiple posts here complaining about model numbers, just ask Andy your questions. Either send him a message on IPCAMMTALK to @EMPIRETECANDY or send him an email to [email protected]
Reactions: looney2ns
The only reason why I might repeat myself about missing model numbers is when the respondent did not understand what I wrote the first time and it had to be repeated.... I did reach out to Andy and I've not received a response..... so, point well taken.... rest assured it's under control.. :)
R
Clearly the EmpireTech NVR 5-EI Series 16 Channels (NVR16CH-AI) is not the NVR5216-XI since the specs don’t match. So since Andy is not available, why international model is the EmpireTech NVR16CH-AI?
EmpireTech NVR 5-EI Series 16 Channels None POE 1U 2HDD Smart AI Network Video Recorder,Face Recognition,SMD Plus,Max. 384 Mbps Incoming/Recording/Outgoing Bandwidth,NVR16CH-AI : Electronics
NVR5216-XI - Dahua International
R
you wrote yourself: NVR 5-EI series...
so it's 5xxx-EI series, not 5xxx-XI series...
this exact model is 5216-EI...
Andy don't sell 5xxx-XI.. this line is not available in the USA (FCC ban)...
You can choose between 5xxx-EI and 6xx-XI (NVR32CH-8XI) in Andy shop..
Reactions: MacFun
[QUOTE="steve1225, post: 878515, member: 98919
yoAndy don't sell 5xxx-XI.. this line is not available in the USA (FCC ban)...
[/QUOTE]
You are correct. Previously I did notice that the 5xxx-EL existed and was only seeing the XI. Thanks for the clarification. All is right with the world.
R
Hello,
can someone explain to me (or preferably link a video) how this works with the lines
IVS - Smartplan -> RuleConfig
Rule
Pixel
Min
Max
I just want a good people detection
How do I configure this?
What does a yellow line mean? What does a blue line mean?
How does calibration work?
I found the PDF ‘Network Camera Web 5.0 Operation Manual’, but I can't really make heads or tails of it. A video would be best.
Thanks
Pixel is if you are drawing around something to get a size. Most don't use it.
If you are using the AI of the camera then leave min and and max at default - min at 0,0 and max at whatever size it is.
Yellow is when you are drawing it. Blue is the IVS rule you saved and set to use.
Calibration only needed if you have a weird field of view and getting false triggers and use that to calibrate heights of objects throughout the field of view. So try camera without the calibration and only use if you get false triggers.
thank you... when i click on ‘rule’ now, a small triangle appears with the double arrow. (I drew it earlier). what exactly does that mean and what should I draw instead?
how can i exclude areas (e.g. the rotating windmill)?
Throughout the night, I repeatedly recognised events such as the rotating wind turbine and flies / mosquitoes in front of the lens.
If the AI works correctly with the ‘target filter = human’ activated and only recognises people, this should not happen...
How can I set this detection reliably?
Edit: In Event -> Video Detection I found more options, as welle the aera-config, where I can exclude the part from recognition.
Event -> Video detection -> motion detection
Event, I can also enable "SMD Smart Motion detection" with sensitivity low, medium, high.
Does this have an impact on the AI-config or does this mean the classic motion detection, without ai? How does this work together?
That’s crazy, but I pulled this for you, car is driving by between 40 and 60 kilometres per hour, u can see the detail with a still. Camera is about 40 feet from the car zoomed in almost full, unfortunately its not a freckle but if you can try to pause the video when u see the car in the middle.. as you will see the driver details..
What settings and shutter speed are you using? What camera model is this? Thanks in advance
