EMPIRETECANDY
IPCT Vendor
aha, 1/1.8cmos for ptz will be bit expensive, this 49xx is lite version, maybe 3-4 years later tech has a big process.
 A pair of Ubiquity Nano links, if you have line of sight.I'm wanting to give this camera a try and install it 650 feet from the NVR, good thing is I have electric 35-feet from the install location. Any suggestions on the best way to manage this? Thanks.
Snip...
Current Favorite Cam List For Those Interested
A little extra as I close this post.
As I get asked this all the time, my current favorites list and those I recommend based on their per class performance and use case are, in no particular order:
49225 - Coming with 2MP, an absolute powerhouse for the price, certainly a rare gem in this category of PTZ’s
5A425 - Continues on the great sensor to optic and MP pairing for the 4MP line providing a great image
5442 - A well rounded and very flexible series of cams that has the pairing of MP to sensor and optics almost perfect
7442 (ANPR Models) - These really are amazing models and 1 of my all time favorites for vari bullet cams due to feature and performance. A Z12 variant in this model would be an amazing addition and would increase the flexibility even further
- Bullet IPC-HFW5442E-ZHE
 - Fixed IPC-HDW5442TM-ASE
 - Varifocal - IPC-HDW5442T-ZE
- IPC-HFW7442H-Z
 - IPC-HFW7442H-Z4
5231/5241 - Due to advances in the other models above, my 2 current favorites in this model are based on their performance for reliable long range LPR (not ANPR of course, for that, 7442) therefore the Z12's only.
- IPC-HFW5231E-Z12E
 - IPC-HFW5241E-Z12E
Looking at empiretechandy's cameras, the model numbers are slightly different than listed above. I understand Andy sells Dahua under his Loryta brand. As an example, is the Dahua IPC-HDW5542TM-ASE the same as Andy's Loryta IPC-T5442TM-AS? HDW vs T, ASE vs AS. Thanks.
It's soooo big lol......Wahoo, congrats !
It came with V2.810.0000001.3.R.P9.2519.UN.NR, Build Date: 2020-06-08 preloaded... worth upgrading?
hmmm.... would a regular POE switch work for this? For some reason, as soon as it starts to detect movement, the whole camera crashes and reboots?
Hmm... I just looked, the budget is fine... but the ports max support 16.2wDepends on your switch. You need to a) ensure POE+ is supported and that b) you have enough POE budget left to support up to 20w give or take on that port.
Hmm... I just looked, the budget is fine... but the ports max support 16.2w![]()
				I had a look, the cheapest pricing was $65!!!! At the moment, I am using two switches.. one is a 8 port netgear managed POE switch and the other is just a netgear switch.... kind of annoying having two.. anyway, so I decided for $150 i'll just buy a TP-Link TL-SG1016PE which is 16-port POE+ switch... and i'll offload the other two switches to family who only need a basic POE switch etc.X2 on the PFT1200
Mast Digital in the UK a Trade only Dahua authorised supplier.Where did you order from if you don't mind me asking
