Digging through Dahua's web site for this camera does not show any limitation for PTZ cycles. I mean if I have a hard drive that is still working after 16 years, with that mechanical arm moving back and forth over the platters 24x7, then really, a properly designed PTZ should last many years as well. To have some hard coded artificial limit is ludicrous. Imagine the uproar if Tesla disabled your car's steering after it was out of warranty, either by range or years.
Not quite apples to apples, but I'd imagine this cycle count is from their own fears of grease migration. I doubt they have a long-life lubrication system. This is why I believe that manual servicing, if the user wishes to do so (may or may not be complcated to access the gears), should not be hindered by the ptz cycle counter.
Hard drives are lubricated a bit differently. Better to compare to grease fittings on an automobile. Even "sealed for life" bearings often have grease migration and break down enough to require replacement if we're talking over 100k miles. Often "life" means 100k miles max, and many fluids "sealed for life" should be replaced well before that time.
I've purchased a few auto-tracking ptz cameras, not knowing about this counter. It would be enough to where I believe a legal case in most USA jurisdictions would side with the consumer, even beyond "warranty" (this isn't currently a warranty claim issue) if the disablement of a key selling feature wasn't disclosed before sale. The difference with Tesla is that they have the money/resources to keep trying to push off a final ruling through drawn out legal battles, and then appeals processes, and it's a financial drain on the plaintiff. A lot try to win legal cases by attrition.
