EMPIRETECANDY
IPCT Vendor
I have a business customer bought 32pcs last week, BUT he will not use autotracking, so i told him we sell him the none autotracking S2, just get him a sample today, The currently AT stocks will be used up in July i think.
I have one 49225xa-hnr. Low light performance is good. But I'd like to have a better option: reaction/tracking speed (autotracking is a must), and better low/no light performace. If 49425 low/no light performance isn't as good which camera I shall look at?Pull the trigger now. The 49425 model is the 4mp model, but because it is using the same sensor as the 2mp model, the low/no light performance is noticeably worse. Don't let the 2mp resolution of the 49225 fool you. Because it is a PTZ, you can zoom in and usually mitigate any "low resolution" issues. Certainly the low/no light performance on the 49225 model is more desirable.
Make certain you are changing settings directly in the cameras interface, not through the NVR.After reading through the thread and trying the tips presented, I cannot get my camera to go back to preset 1.
Idle time seems not to do anything. As en edit, I am using the Dahua 5216 4ks2e NVR.
Task time, I get an error. I tried to delete record scheduling, etc... as another user worked for, but no go.
I'm using spotter cams as well, and in the process of getting those settings correct.
Most likely missing something obvious, but... I can't seem to find it.
Perhaps a tour set up? My question with that is, I pretty much just want it to stay at preset 1, unless I move the camera manually, or the spotter cams pick something up.
Thanks all.
Yep. Have a dedicated laptop with IE plugged directly into the NVR.Make certain you are changing settings directly in the cameras interface, not through the NVR.
And that you are using IE and not edge for the browser.
Then move to the higher version SD5A425XA-HNR 4MP 1/1.8CMOS, everything on this camera has big improvement, sure price is higher.
Review: Dahua SD5A425XA-HNR 4MP 25x Starlight IR PTZ | IP Cam Talk
It has S2 version and S3 cheap version,but can't support autotracking anymore.When will this become available with SD4xxxxx model # ?
Check if the RJ45 port has leakage or not, looks like the RJ45 connector burned.When will this become available with SD4xxxxx model # ?
