Thanks!That should do it!
You still need to set the Sub Stream Frame rate to 15, and the I frame to 15. They need to match the Main Stream settings.I'm a little wishy washy on the Main vs Sub streams. When is the sub stream used?
looks good now?
I had gone through these when setting up BI, but it sounds like i could use a refresher. My cpu usage is around 15-20% for the system (5 4k & 1 1080ptz).If you are doing EVERY optimization in the wiki, it brings the CPU down tremendously, allowing it to operate properly without jerky video and what not. Substreams are a must now to keep CPU low. Enable the substreams in BI if you haven't already and watch the CPU drop.
You need to match the substream FPS and iframe to the mainstream - make them all 15.
Optimizing Blue Iris's CPU Usage
Blue Iris uses a lot of CPU time. In most Blue Iris installations, your CPU is the limiting factor which determines how many cameras you can have. As such, it is extremely important to optimize your configuration to ensure you can get the most out of your system while consuming the least...ipcamtalk.com
Thanks, I changed it to match the mainstream 15 rate and i frame.You still need to set the Sub Stream Frame rate to 15, and the I frame to 15. They need to match the Main Stream settings.
Take time to view these: Blue Iris Support - YouTube
Its an i7 4790What processor do you have?
I am on a 4th generation CPU with a lot more than 6 cameras and my CPU is less than yours...
I couldn't believe it cut it down to about half of what i was! I'd better start shopping!Isn't it great? Now you can add another 10-15 cameras without your CPU breaking a sweat![]()
In the individual camera settingswittaj, ".....check your settings in BI and make sure it is set to trigger and fire on motion."
Where do you set this? The Profile?
