I have it at the corner of my garage under the eve. No issues at all.
that makes logical sense, thanks. So...do not position it in the walkway where the subject walks underneath itSame here but opposite corner. I had mine above the garage but it struggled to track anyone who walked straight up to it since they would fill the image frame. It routinely lost them as they had to walk almost directly under it going to the front door. I moved it opposite side of the house and it does a wonderful job now.
With tracking you need the target far enough that it has plenty of room in front of them to keep in frame while they move. When they get so close it's just their face its, too easy for them to walk out of frame and the PTZ loses them.
at what distance would a person hog up the image enough for the camera to get whacky? 10'? 5'?Same here but opposite corner. I had mine above the garage but it struggled to track anyone who walked straight up to it since they would fill the image frame. It routinely lost them as they had to walk almost directly under it going to the front door. I moved it opposite side of the house and it does a wonderful job now.
It all depends on when the camera tracks them and what tracking size you use for that deep IVS (not the object size, the tracking size). For example, if you have it start tracking someone at 150 feet out and have the tracking target size at 60, then by the time they get close to the PTZ they appear to be "moving" too fast to be tracked because they consume such a large part of the image at that point.
So I have one of my closer cameras set up as a spotter cam that then "resets" the view to a wider preset and a smaller tracking size as they are now closer to the camera.
I set my neighbors PTZ up in a similar fashion - he put his on the first floor eave of the garage and guests literally walk under it to walk from the driveway to the front door and it tracks them flawlessly using this method. Once they get to a certain point on the driveway, another preset is called that "resets" the PTZ to a preset with the tracking target size of around 15 so that this can happen.
When neighbors park in their spot, it is 99% of the time as close to front door as possible. But when visitors over, yes... it could be a rare issue. I'll put at option 5 for testing purposes. Easier to install on 6' ladder too@Holbs - I like the option 5 for the points you highlight; however, the area looks flat and from that location looking up to the main street - you get your neighbor parking in the driveway with a vehicle of any size and you probably are not tracking anyone coming down until they are past that vehicle. Camera at night with even a sedan in the driveway only seeing an upper torso could struggle identifying it is a person. Personally I would go higher to start tracking them walking up at the main street and count on the lower cameras to get good ID where the PTZ can't at close range.
nobody in this house but me & my mossberg shotgunOr mount it between the windows on 2nd floor from the window lol (it looks like they could open such to accommodate that lol)
