@looney2ns just back to work,i have a question about this dual camera working on the NVR, i can't get 2 pics, just one on the NVR, have you ever test on your NVR4216-16P-4KS2? if you have any idea, please let me know, Thank you!
Sorry, for the delay, just remembered this.
I have success on adding the 2nd channel to the NVR.
After adding the first channel, go back and do a manual add.
Use the same IP address that the NVR assigned to the first channel.
Hopefully the following screen shots will explain the rest.
Choose the proper dropdown for the next channel
Click Connect after filling fields
You will get this popup. Select yes.
Select only the 2nd channel
Click Apply and you should be up and running.
