It's a directed UDP packet after the ARP response for 192.0.0.128, not a broadcast.It doesn't try to access any tftp server and there is no unknown or magic udp packet send by it.
It only tries to access the Hikvision tftp updater.It doesn't try to access any tftp server
You could check that the probe for the Hikvision tftp updater is active by setting the PC IP address to 192.0.0.128, run the updater but with no digicap.dav payload in the folder, allow the inbound firewall rule, and see if you get the 'client at 192.0.0.64 test the tftp server' (or siimilar).My guess is that some cameras have tftp disabled. Is there a way to tell camera to enable it?
Yes, these are R0 series cameras that can be converted to EN and fully updated by using the brickfixV2 method :Been trying to get confirmed that these to cameras are doable to upgrade
But be sure to get the devType value by using the prtHardInfo shell command
The -IW variant may not be in the existing devType codes list in the post.
This would be done over telnet with the camera in its current working state, using a terminal program such as PuTTY.Do I use this prtHardInfo shell command in HxD u mean?
What I'd recommend is to read the ste-by-step guide and the enhanced MTD hack instructions - then use the video to confirm understanding.The one part i didn't get watching video first time was when u change the 02 to 01 on the second row i HxD?
I'm assuming that old firmware still has the 'Enable telnet' option in the security settings of the web GUI.
It's only because I don't have the devType listed for the DS-2CD3132F-IW model.
Well done! Good to know. Thanks for posting.A bricked 2432, not only now fully operational, but patched.
Great! Well done.Just fixed up two bricked R0 cameras
A good way to learn!I did only have one bricked but then my amatuer unguided ateempts at fixing the failed one trashed the other.
No, this model of camera has a completely different architecture from the R0 series.Can I use this method to put the firmware of a DS-2cd3125G0 on the cheap chinese version???
Sorry, I've not seen that device, so have no idea what would be possible with it's firmware.Tell me please, can change the language zone from Chinese to international?
