redstorm666
But you might want to re-consider the external access - even with the updated firmware, there are considerable risks in allowing access to the whole internet.
You're right, I've already reconsidered my configuration and have configured a secured VPN to access my cams.
My first cam got hacked less than 24h after being exposed on internet (this cam was unused since monthes, I've put it back online 2 days ago with the original 5.3.0 fw).
The 'hacker bot' had access as admin to the cam and the log shows a 'full config export', which means the hacker could have had access to my setup including NAS storage config/credentials etc.. my first reaction was to try to upgrade the fw which resulted in the brick-ification, and my second thought was to move to VPN config to avoid putting such a fragile component in the wild open internet.
Btw, my 2 others cams (another 2CD2032F-I and a 2CD2132F-IS) has been upgraded to 5.4.5 using same process, and same success : thanks again.
