What are the specs?  With the newest versions and substreams, you can get by with a 4th generation CPU...
And this is one of the many reasons why many here go to
Blue Iris...an $80 NVR off Amazon will not cut it nor will that all-in-one box kit from Costco LOL....but for several hundred dollars just for the NVR you can start to get capable NVRs.
I'd recommend you consider a
Blue Iris/computer combo as an NVR. Keep in mind an NVR is a stripped down computer after all....and isn't true plug-n-play like people believe. You still have to dial the cameras into your setting. Once you do that, might as well go with something that has the best chance of working with many different camera brands. And I have found
Blue Iris to be more robust and easier than an NVR. As always, YMMV...
When I was looking at replacing an existing NVR, once I realized that not all NVRs are created equal, and once I priced out a good one, it was cheaper to buy a refurbished computer than an NVR. You don't need to buy components and build one, and your computer may be sufficient.
Many of these refurbished computers are business class computers that have come off lease. The one I bought I kid you not I could not tell that it was a refurbished unit - not a speck of dust or dents or scratches on it. It appeared to me like everything was replaced and I would assume just the motherboard with the intel processor is what was from the original unit. I went with the lowest end processor on the
WIKI list as it was the cheapest and it runs my system fine. Could probably get going for $200 or so. A real NVR will cost more than that.
A member here just last month found a refurbished 4th generation for less than $150USD that came with Win10 PRO, 16GB RAM, and a 1TB drive.
Blue Iris has a demo, so try it out on an existing computer and see if you like it.
As I said, keep in mind that NVRs from the box units like a Amcrest and Lorex cap out incoming bandwidth (which impacts the resolution and FPS of the cameras). The Lorex and Amcrest NVR maxes out at 80Mbps and truly only one or a couple cameras that will display 4K. And I mentioned my neighbor's was limited to that and he is all upset it isn't 4K for all eight channels and he was capped out at 4096 bitrate on each camera so it was a pixelated mess.
There is a big
Blue Iris or NVR debate here LOL. Some people love
Blue Iris and think NVRs are clunky and hard to use and others think
Blue Iris is clunky and hard to use. I have done both and prefer Blue Iris. As with everything YMMV...
And you can disable Windows updates and set up the computer to automatically restart in a power failure. These also tend to be more secure as antivirus software is updated way more frequently than NVR firmware.
