fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
Many cameras have 1 or 2mp sub/third streams....you will not me able to discern a difference when in matrix view...View attachment 179025
They are both using Code Project. I do not use and do not like using sub streams as I prefer to be able to see the cameras live view as sharp as I can. Only 3 of my cameras support using Intel Hardware decode.
Not an issue with the i7-6700. Sometimes 2-3 of my cameras detect motion at the same time and the CPU can take it, no issues.Many cameras have 1 or 2mp sub/third streams....you will not me able to discern a difference when in matrix view...
When images are processed by codeproject your cpu must skyrocket.
Are you using substreams? I am not.What is the full BI Camera status page - we need to see the substreams and the MP/s numbers at the bottom.
So you only have 6 cameras? I have more 8MP cameras than that on a 4th gen running CPU% lower than you, plus a whole lot more of 4MP and 2MP cameras.
Unless you have code project set to low you are definitely pegging that CPU or you are not properly monitoring it... It would probably peg even if you set it to low..Not an issue with the i7-6700. Sometimes 2-3 of my cameras detect motion at the same time and the CPU can take it, no issues.
They are both using Code Project. I do not use and do not like using sub streams as I prefer to be able to see the cameras live view as sharp as I can. Only 3 of my cameras support using Intel Hardware decode.View attachment 179026
I understand what you are saying.. it still doesn't explain why the new CPU only lowers the utilization by no more than 10% when they are both using the same AI.
Wow.. this is why I dropped out of high school lol
