Did you ground the Faraday cage?they are metal framed. i tried wrapping a camera in 8 layers of foil, but it did not do anything
Nothing like an elegant theory ruined by an inconvenient fact.they are metal framed. i tried wrapping a camera in 8 layers of foil, but it did not do anything
The OP has already ruled out cabling issues. He said that he can have a camera plugged in with a picture, and simply walk to that side of the house and the Image will go black. The simplest, and most logical explanation has got to be the alien theoryNothing like an elegant theory ruined by an inconvenient fact.![]()
The one other bit of advice that I would give is to buy a network cable tester, and confirm that the cables in question have full continuity, e.g.
I would never rule out cabling issues until I had performed a continuity check of a cable with it installed in place. A cable under strain may show a failure that a loose cable will not. Install the cable and camera, wait until the camera drops out, then disconnect the camera and check the cable without moving it.The OP has already ruled out cabling issues. He said that he can have a camera plugged in with a picture, and simply walk to that side of the house and the Image will go black. The simplest, and most logical explanation has got to be the alien theory
in which case they’ll come out and replace it?Above he said that he contacted them. They also didnt know that their devices are RF.I would get onto the gas supplier, reason being that they may have come across this problem before and may have a solution? For example the meter may be faulty and frying your brainsin which case they’ll come out and replace it?
Dealing with RF interference from other devices is completely beyond the experience of most customer support types. Amateur radio operators learn about it, but there's a huge variety of electronics that are designed and manufactured in China with absolutely no provision or shielding against RFI. Outside of a particular environment the device in question will work just fine, so of course the person testing it will find no problem with it.Above he said that he contacted them. They also didnt know that their devices are RF.
Sent from my SM-G965F using Tapatalk
