Just sent a request to Ken and he replied almost immediately.Email Ken and make a request. The more requests he receives, the more likely he'll consider the feature.
"We will add this to the list of feature requests. Thanks for the suggestion!"
Yes, there are several IPCT members with Tempests ( @mcapeed , @Smilingreen ? ) not sure of those that also use Blue Iris but maybe could utilize some HA-type of integration.Would be very very cool if you could have it pull stats directly from Tempest
I have a weather station in my back yard, seems silly to get other data from the internet
If you mean the openweathermap current weather API, it does return temperature and windspeed with more precision, which Blue Iris macros %053 & %057 apparently return as rounded or floor integer values.I have the new Weather API working, but I am trying to find a way to display the temp and wind speed with more precision. I would like to display the values to at least one decimal place. Is there a way to do this?
Thanks for pointing me to the explanation. Lots of good information in the post and follow-up you pointed me to, as well.The apparent reason why Blue Iris macros %053 & %057 are integer values instead of floating point numbers is because Ken opted to store the values in the registry as REG_DWORD type keys. See this post, and my follow-up.
I guess I need some hand holding here. Are there more in depth instructions somewhere? I shut down BIT and deleted the macros that came from BIT. Was I wrong to do that? I entered my key on the Location tab of BI. I'm not sure how to proceed from here.Keep in mind, it took a few hours for my key to work in BI, it said active on OpenWeatherMap.Org but would not work in BI. You will know when it works as it will populate the conditions and won't get an error message. No need to put CC info in or nothing for the free API service.
Current weather and forecast - OpenWeatherMap
OpenWeather provides comprehensive weather data services, including current, forecast, and historical weather information. Explore a wide range of APIs for solar radiation, road risk assessment, solar energy prediction, and more, with global coverage and user-friendly access. Ideal for...openweathermap.org
I emailed Blue Iris Support about the temp and wind speed precision. Ken has modified the existing %053 and %057 macros so that they include one decimal place of precision. He did this in version 5.9.9.43If you mean the openweathermap current weather API, it does return temperature and windspeed with more precision, which Blue Iris macros %053 & %057 apparently return as rounded or floor integer values.
You will need to email Blue Iris Support and request new macros like %053 & %057 that provide the same precision as returned by the API.
Here are the new registry keys (REG_SZ key types) ... highlighted in red.I emailed Blue Iris Support about the temp and wind speed precision. Ken has modified the existing %053 and %057 macros so that they include one decimal place of precision. He did this in version 5.9.9.43
You don't need to add any macros in BI. Ken has done the work for you. Just go to the cam and select "Edit overlays" then select "Add text/time" You then add the values you want as I show in my picture. I do not use all of the data, but you decide.I guess I need some hand holding here. Are there more in depth instructions somewhere? I shut down BIT and deleted the macros that came from BIT. Was I wrong to do that? I entered my key on the Location tab of BI. I'm not sure how to proceed from here.
Using the OpenWeatherMap service does not require a personal weather station.Is there a way to make this work if you do not have a weather station? Does a API need to be entered and if so how to get one. I feel lost in the forest...![]()
You will also want to make sure the BI Location tab has your correct coordinates, or you will end up with the wrong weather conditions. Get Lat Long from Address Convert Address to CoordinatesThanks, I didn't see that. I will take a look.
Thank you, working like a charm...It's right there in the Help PDF... try clicking the Help button on the Location tab
You're seeing temperature in absolute Kelvin degrees. On the Location tab, change the units to Metric or Imperial...I just setup the openweathermap api in blue iris. It seems to be working fine but the temperature is way off. It's showing 291.3 degrees. Any of the temperature fields are showing similar high readings. Any idea what could be causing this and a fix. I really like having that info on an overlay.
Thanks!
