nayr
I will need to figure out a way to remove the soffit so I can see what I am going to drill into... I am not sure how difficult that will be since I have never done it... Then I am planning on drilling trough the eave and then run the cables into the attic where I will install a power outlet for the camera
You need to be sure whether you'll be able to do anything before the drywall and how much time you'll have and what the state of the house will be. If you've never done this before it may take you longer than you expect.Ill have one or two nights to run the cables before the drywall goes up...
Hello... when you say ... "Don't put an outlet / transformer in your attic. Run some 16-2 with 2 Cat-5e to the power hungry cameras." What do I connect this 16-2 wire to ? If you look at te bedroom near the cameras ... There is a box in the ceter of the room that I was going to jump off of and make a outlet box. I spoke to the electrician and he said he would do it if I wanted ... Maybe he will run this 16-2 wire if I can figure out what your idea is FYI: this is an example of a wall mounted rack: http://www.tripplite.com/smartrack-...osure-cabinet-clear-acrylic-window~SRW12U13G/Yea... That is an air duct �� So is the one in the master closet.
power line networking can be trouble in newer houses with AFCI breakers, depending on the brand of your breakers (iirc Square D and Eaton are Ok everybody else not so much) these adapters can trip your afcis. These basically work by injecting noise into your power lines, so they don't go so well with high end av equipment.those are a thousand times better than WiFi, but a real ethernet cable is many times better than PowerLine Networking...
Indeed.dont ever install anything from china, good way to get your ass infected.
one is FastEthernet (10/100Mbit) and the other is GigE (1000Mbit), obviously you want the GigE one.
https://www.youtube.com/watch?v=sR-h64WwfW8
I remembered seeing a photo of your front door from a few years ago in one of your other threads, that showed a smartkey lock and I thought there was a reference to getting one of those smart locks that screws onto your existing lock. I thought there was a good chance it had been replaced, but people still buy these insecure locks. There's even a socket wrench version of the tool to open the smart key locks.are you talking to me? My front door takes no keys
