Thanks. I may take you up on that when I have some free time. But at the moment I have some fires to put out, so I'm going to limp along with my one chimeIf you want to try any other firmwares I have I would be happy to post them...
, and maybe try one of those eBay chimes.Wonder if there is something ReoLink did to the newer DBs to stop third party Chimes
Uh oh. This Reddit thread suggests that the newer Reolink doorbells units are now using 900 MHz RF to connect to chimes, linking out to this Home Assistant thread with more details:
I haven't had that problem yet but I can see it coming and apparently you already have or are anticipating it.Does anyone have a solution to prevent people from using a paper clip to pop the doorbell off its bracket? Seems pretty easy to mess with the integrity of the doorbell itself; exposed network wiring, microSD card, weatherproofing, resetting the doorbell itself, etc.
community.home-assistant.io
I remember having a magnetic contact on our Alarm panel so when the panel door was opened, while the Alarm was Active, it would set off the Alarm system...Prevention is the best, IMO but if it was a frequent issue I'd install a tiny micro-switch with lever and when the pin was inserted and the latch moved initiate some sort of alarm and send a Pushover alert, etc.
In that linked scenario the perp is there A LONG time.....in this case I think a tamper switch with remote and audible alarm would be in order.Wow, did not think about this, if someone removes the POE Doorbell they could potentially have access to your network, if it is not secure...
POE doorbell security
Hi Not directly Home Assistant related yet but this is the first step. I am looking to install a Reolink POE doorbell and having very little network knowledge was unsure if there is a security risk having an ethernet cable running into the back of the doorbell. If someone were to remove the...community.home-assistant.io
I understand this would be rare and could happen to any camera, just did not think about it...
Now this was a great find...Now this looks promising (and pricey):
Reolink WIFI/ POE Compatible STEEL Doorbell Guard Cover Protection Case Security - Etsy
This Hooks & Fixtures item by DoorbellGuard has 18 favorites from Etsy shoppers. Ships from Chatham, IL. Listed on Aug 8, 2024www.etsy.com
