This is my update to 101, let me know if I missed anything or need to change it:
ADDITIONAL TIPS:
⦁ For RCA owners (ONLY); if you want to remove the RCA Logo, we found a trick in doing so. You will need to install EZVIZ firmware build 190708 first, then turn ON Logo in Batch Config. Tool (Remote Configuration/Image/Video Display), then load LaView's firmware (which will turn Logo OFF)
⦁ For EZVIZ owners (ONLY); if you plan to install/upgrade your firmware to LaView's firmware you NEED to be sure and follow these steps: First Check your firmware in your App under Settings. If you have build 190304 DO NOT install LaView's firmware (If you do you will end up with a RCA Logo). If have the 190304 build you will NEED to update your firmware to EZVIZ build 190708 first. Next; with the 190708 build installed/confirmed go to Batch Config. Tool (Remote Configuration/Image/Video Display) check to see if the Logo is checked ON, if so, you will need to uncheck it Off before installing/upgrading to LaView's firmware.
ADDITIONAL TIPS:
