So i managed to install the Nelly Security Video Door bell and i used Ezviz app at first to do the install, it was really easy to do the install and to setup the app.  I have try the door bell and the app was responding very good, the wireless router is in my office on the second story witch sits in top of the entry door / patio at front door , so  it is only about 10-12 ft from the door bell to my wifi router.
Firmware that is in it right now is:
v5.2.4 build 190412
Nework signal: -45dBm  (Looks full signal icon in the app), Using the same transformer 16v10va from post#961
Now, while playing with the Ezviz app it worked fine at first , like i was pressing the video bell outside and then i get notification on my phone and i can answer that. But after 30 min or so of playing it kind stopped working, not sure if i screw up something in the app settings or what.... so then i remember talking to Nelly Security support and they said to use hik-connect app (have iphone 11 pro plus/max), and the hik-connect worked fine , looks like.
Few things i have not find out how to set up, like:  (using hik-connect app)
*How to decrease the door bell outside ringer speaker volume? or to turn it off. i kind don't want for it to ring at all outside or if i can lower it down.
*How to change shape of the video view , right now is like a oval left to right.
And i think was something else, but forgot what it was....
Anyway, now adding the video door bell to BI.
As i moved to a different home had to install back few of my cameras and setup all back and also my dedicated Dell tower specific to run BI.  Now, after putting up the cameras, when i try to  start the tower , computer took a crap and did not want to boot
and after few ours of trying this  and that , my sandisk ssd 240gb took a crap! Will never that hdd brand again and is only about one year+ old. Anyway, fixed my pc with a regular 2tb sata hdd and all back in business, installed a trial of the BI v5  (i did had a v4 paid key from before) , after the trial of v5 is installed , at activation enter your v4 key and then the system will ask you if you have a Maintenance and Support key purchased from BI site, witch is $29 and it lets you update from v4 to v5, then did that and now i am in Business with BI v5.
Finding the Video door bel ip was easy just looking at my wireless router connected ip's , in admin @  192.168.1.1
Adding the Video door bell in BI was easy once i found the password...hmmm
For others that want to add it in BI the user name is: admin and password is on your  Video door bell quick start guide booklet
Here is the Settings i have in BI:
Right now i get streaming and looks that is working fine, and have it recording 24hr's a day. I have not checked anything else yet ,like: audio, notification,etc...in BI yet.
I got the new firmware from Nelly Security and they told me that if all works fine i do not need to upgrade. In my network my tower is using the video door bell , i have the BI app on my phone and also a family member has it .
Anyway this what i have done so far regarding the Video door bell. Looks that is way better when it comes to video image  than Ring, Nest,etc... Wyze is working on a new video door bell, not sure the specs and that could come with onvif enabled.
