Chen_Arets
Well. the story continues...Flashed the Ezviz DB1 with the Hikvision 211101 fw again with the batch configtool based on setting: Part restoration. The app notifies me that I need to upgrade the FW to the Ezviz version 5.2.4 build 230404. As I don't want to upgrade to the Ezviz FW (it doesn't support Onvif), I ignore it. I am using the latest Hik Connect iOS App. 2 days in a row the following happened: Around 2am the DB1 gets disconnected from Wifi, but restores within a minute, the morning after the DB1 is offline...so I need to reset it and connect it back to wifi...but guess what? My Doorbell has been upgraded to  version 5.2.4 build 230404!? All by itself without me doing it. How can I disable auto-update? I am almost on the verge of getting rid of the DB1, but for me it's the ideal camera if it's flashed with the Hikvision FW and it works with my mechanical chime and onvif NVR...so any help is appreciated!
