To set PIR distance you will need to do that in the App:Is there another way to configure motion detection? This setting does not seem to do anything.
I know someone here fixed a similar display issue on his Show by turning off video encryption in the App, I don't even know if that option still exist. You might try the Sub Stream to see if it displays different on your NVR.Just replaced a client’s Ring with InVid version NDB313 to add to Uniview NVR via onvif. Updated to newest hik firmware with batch configuration tool with no issues. Added to NVR with no issues, except picture only fills half of the screen no matter what I do. Only thing I noticed is feed is being seen as 1536*2048. Any way to stretch image or have it display differently? We have feed from NVR showing on TV and it looks ridiculous. Fine on app, iPad on full screen mode.
curl --digest -X PUT -T /home/somebodieshome/ss.xml "http://admin:secretpassword@ipaddress:8000/ISAPI/Image/channels/1/ISPMode"
<?xml version="1.0" encoding="UTF-8"?>
<ImageChannel version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<IrcutFilter version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<IrcutFilterType>night</IrcutFilterType>
</IrcutFilter>
</ImageChannel>
I know certain SSID names won't work, that is certain special characters, spaces, underscore, etc. Is your SSID simple?Question: I just got a new Wifi 6 Mesh system ( TP-Link Deco AX3000 (Deco X50)) and I've been trying to connect all my EZVIZ and Hikvision Wifi Cameras to it but they are not accepting the SSID (well the config app says its saved) but dosnt connect to new network. what is the text file to SDCARD way to config SSID and network Password again? ive searched and cant seem to find how to do it.
thanks in advance,
Not sure which text file you are referring to but to change network settings on Hikvision/EZVIZ use Batch Config. Tool.
HTH
Nor do I but do get an image in the Image Settings...but I am also running an older firmware...What the correct BATCH CONFIG util to use with the HIKVISION V5.2.4 build 211101 firmware? I was running the older version mentioned here and it was working fine before I started changing firmwares and now I can't get a video image on the motion_event or the image settings sections.
running windows 10
Yep, has to be firmware version...if you need any older ones to go back to let me know. I have a small collection...Tried your exact combination and it didn't work for me, at some point in the past I had a version working where I can move the day/time stamp location on the screen and now I can't do it anymore.
This is a Huge discovery/Fix...Thank You...this should help many here...Wireless Routers and Access Points - All Brands - Airtime Fairness feature
Last week, I finally realized the likely solution to my frequent DB1C connectivity failures. There's a wifi config parameter called airtime fairness. Years ago, it caused problems with poorly-coded wifi firmware. Well, the "feature" is still there and it was enabled. Just disabled it again and rebooted the router mesh.
This appears to have resolved the issue. In the five hours since i turned off the airtime fairness feature, there has not been a single connection failure. Over twenty-four hours later, and there are only four connection failures. That is entirely acceptable.
FYI, I informed the EZViz customer service team, they should be aware of this wifi feature causing connectivity issues. Many newer routers default this feature to ENABLED.
Password is on the back of the Doorbell. It is 6 Characters Capitalized, ex. ABCDEFI have the EZVIZ DB1, flashed LaView for ONVIF+Alexa support, without restoring the config, the doorbell appears to still work and ONVIF is running.
Just need to figure out the password, is it written on the box or do I have to pull out the doorbell?
If I update the firmware from the EZVIZ app, will it go back to the EZVIZ firmware and I would lose ONVIF?
Does LaView have its own app and is there an newer firmware version than 190716 ?
