Let us know if you notice anything different with the new firmware...thanksI updated using the HIK-Connect app, my DB1 has the stock Ezviz firmware. Version is at the bottom of the pic.
I'm also UK based.
I'm also UK based.
Sorry for all the questions, I think of them as I read, so does your NVR have the latest firmware? You mentioned it was a known problem with your NVR, just curious if there is a newer firmware...
Gotcha, hopefully they will have a fix soon for you...I purchased the NVR from Andy and it has the most recent fw, he said that it’s a known bug with no fix as of yet.
support.nellyssecurity.com
Thank You...did you just recently get a notice to update?Just updated my EZVIZ DB1 doorbell via the Guarding Vision app to firmware v5.2.4 build 220530.
"NO ONVIF" as it seems.
So sorry I missed your URL link, wow, very impressive...where were you a few years backIf anyone is interested, I made a replacement button for the black face plate, which I hope will stop people pressing the PIR sensor. Here's a before and after pic:
More pictures of the process are here: Making a New EZVIZ DB1 Button
What version of the Batch Config. Tool are your running?Hi everyone, first thanks for this awesome thread - it's amazing!
Second, I'm trying to set up a Ezviz DB1 using the Batch Configuration Tool. I've got it connected to my network and the doorbell shows up in the bottom half of the config tool, but when I select it, the option to "Add" it, is greyed out. The option next to it to "Activate" (which I know not to do) is available, but the "Add" next to it isn't. The only thing I've done beyond connecting the doorbell to the network via the Ezviz app is assign it a static IP address through my router. Could that be the problem? If not, has anyone seen this before and/or have any suggestions for how to get it added into the tool?
Thanks!
Thanks for the reply! I'm using v3.0.2.6 (found here: New RCA HSDB2A 3MP Doorbell IP Camera)What version of the Batch Config. Tool are your running?
In case it's useful, I took a lot of screenshots during my use of Batch Configuration Tool and included them in my post here. It took me a while to figure out that you need to check the box, not just select the device, before menu options become enabled. It's not intuitive.Thanks for the reply! I'm using v3.0.2.6 (found here: New RCA HSDB2A 3MP Doorbell IP Camera)
Yes, it's very useful! Thank you so much for your post, that's how I got started with this doorbell and really appreciate all the work that you did to put it together!!In case it's useful, I took a lot of screenshots during my use of Batch Configuration Tool and included them in my post here. It took me a while to figure out that you need to check the box, not just select the device, before menu options become enabled. It's not intuitive.
Your screenshots are actually exactly why I'm not sure why mine isn't working, because mine looks different then your screenshots (using the same Batch config tool version you recommended). Here's what I'm seeing with no ability to select "Add" (in step 3 of your screenshot):
Agreed - I noticed the same thing that mine says Inactive for Security, but I can't figure out why that might be. I used the Ezviz app to connect it to my network (but plan on using one of the apps you recommend in your article going forward). Maybe setting it up with a different app would change that?I'm afraid I have no insights here, except to agree with you that it's strange. I noticed your "security" is listed as inactive while my was "activated" but I don't know what that means.
The other option available to you is to use the "Add" button at the top menu bar to explicitly add your device using your IP address etc. This should bring you to a screen like this one (where password is your "verification code"). If it doesn't work for some reason, hopefully it will give you a helpful error.
