I think it is sourced from Hik VIsion. If you go off of the Max Address It is made by AzureWave Technology Inc.  The MAC Address starts with: 40:9F:38.  When you log into the iVMS-4200 app, it shows it is made by EZVIZ and claims to be a model CV330.  I updated it to V 5.2.4 Build 180719 with the RCA Security Application.
I had to look at my DHCP server logs to get the address.  Once I did, I was able to get it into
Blue Iris using the standard Hik Vision RTSP URL. rtsp://ipaddress/Streaming/Channels/101/  I used the username admin and the password that is on the front of the camera and the install guide.  It never prompted me to change that during the app install.  It does not have a WebUI. Out of the box it has a very high saturation setting as shown in the attached picture.  I was able to log into it using Hik iVMS-4200 and change the saturation levels and turn off the date/time stamp, also attached another image. Blue Iris provides the date and time for me so I removed it from the source.  Blue Iris has had no issues so far with keeping the RTSP stream going.  It has been running for about 8 hours at this point.  I am getting a bunch of video artifacts that were occurring even before I added Blue Iris to the mix or messed with any settings in iVMS-4200.  You can see that in the attached image as well.  Another thing you can adjust in the iVMS-4200 app is the video quality.  Up to 22fps is selectable.  Default is 12.  I have played around with setting it up to highest levels.  I didn't see any performance issues with doing that.  The wifi does seem to have a very low signal even though it's less than 10 feet away from a Netgear Orbi base station.
The RCA App seems to be working fine, however I do see the memory card getting exceptions quite a bit in the app. I witnessed the same thing in the iVMS-4200 App. The button press/call feature in the app is taking up to 1 minute to start ringing the app.
I am using an Edwards 30va 16v transformer and the exact same mechanical doorbell as shown in the guides.  I have the included power kit installed as directed.  Below you will find pictures I have grabbed from the app.  I used overlay features in BI to cover up the RCA logo with a black square as you can see in the picture with the video artifact.  I have opened a ticket with RCA to get that looked at.  I may need a replacement unit.
I will let everyone know how the night vision works out tonight.
