Just got my EZVIZ db1 today. How do I load a different company’s firmware? I tried looking through the thread a bit
Thank you Jack, will include in 101...I'm using this relay (see picture: Finder 39.11.0.012.x060, in parallel with the powerkit).
The relay and DB1 are powered over a 12 V AC (15VA) transformer.
The relay activates a 433 MHz transmitter: ACDB-7000BC Draadloze Deurbel Set | KlikAanKlikUit.
I use RFLink and Domoticz to pick up the transmitter.
Make Sure you Update your EZVIZ firmware to the latest firmware 191211 First, which can be done in the EZVIZ App, Before you try one of the other firmwares, LaView's or Nelly's.Just got my EZVIZ db1 today. How do I load a different company’s firmware? I tried looking through the thread a bit
| Model / Firmware | ONVIF | Alexa | |
| EZVIZ Build 191211 | No | Yes | Yes |
| Nelly's (NSC-DB2): Build 190625 | Yes | No | Yes |
| LaView Halo ONE (LV-PDB1630-U) | Yes | No | Yes |
Thanks for the 101, you've answered almost every question I thought of.
I bought two of the EZVIZ DB1. Before I can install them, I need to redo the wiring for my doorbells. This is how the doorbell on my 70 year old house has been wired:
Not that there is anything wrong with that.I'm going to remove all the cloth covered stuff, and replace with new bell wire, and proper wirenuts.
I'm also going to replace the transformer, since the output of it is a bit "off" (and based on Ring, they recommend 30A for two doorbell's)
So has anyone done two doorbells? Would I use two Power Kits? (To Steal a picture from the Ring site)
So after I upgrade to the latest Firmware (I see that repeated quite a bit) I'll try to hook it up to my Milestone Xprotect system. Hopefully I can do it via RSTP. I'm really keen to try to do the Google integration, and based on the 101, it seems ONVIF and Google are mutually exclusive at the moment.
I'd like to make a suggestion to change the format to a table like this in the 101
Model / Firmware ONVIF Alexa EZVIZ Build 191211 No Yes Yes Nelly's (NSC-DB2): Build 190625 Yes No Yes LaView Halo ONE (LV-PDB1630-U) Yes No Yes
I would try VLC and see if you can connect there first.Hello guys.
I got a HIKvision NVR at home, and just installed an EZVIZ DB1.
The NVR detected the DB1 as beeing a HIK camera.
But when activating it, its asking me for a username and password.
I tried admin as a login. For the password, I tried the verification code of the DB1, but it doesn't work.
Am I missing something ?
Thanks !
So looking at your picture I gather each individual wire is wrapped in the cloth jacket. I bet that is some good wire if it is copper. If it were me I would keep it, you just may have to tone it out to identify where it goes New RCA HSDB2A 3MP Doorbell IP Camera, toners are cheap now a days, I paid over $100 for my Fluke (#3) back in the day. But if it is aluminum definitely replace it, hard to tell in pic. If you do get Bell wire, be sure and think of distance and get the correct gauge.
Yes, two Doorbells, one Chime. I don't think I'll get two rings at once.You have two existing Doorbell Buttons, correct and only one Chime? If so a 30va transformer should work fine. But if both Doorbell buttons are pressed at the same time, which what are the odds of that, then it does not hurt to go with a 40va trans. Most of us use a 30va trans. for one Smart Doorbell. If it were me I would use both power kits, one for each Doorbell. The power kit regulates power to the Chime from the Doorbell when the Button is pressed.
You are the second new RCA owner with this problem:I got mine yesterday, installed it today and apparently bricked it two hours later.Tried to install the Nelly's FW using Batch Config...said successful, then the DB went offline after reboot (I figured the FW wiped the wifi info since it never came back). Went outside; red ring around the db now. Pulled power for an hour (red ring died). Applied power and red ring instantly comes on. I tried the reset button (figured I had nothing to lose), but it doesn't function. Tomorrow I will try to put the RCA firmware on SD to see if that works...any other suggestions would be appreciated.
I just bought the RCA version and tried to flash Nelly's firmware on it using the batch config. It said it was successful and was rebooting but this actually bricked the camera.
The doorbell button is solid red, reset button does nothing as well as power cycling. I tried loading the digicap.dav file directly onto a reformatted (FAT32) SD and rebooting in hopes that it would load the firmware as some others have suggested and still no change in behavior. Anyone else run into this issue or have some suggestions on what else to try?
Sent it back and installed the EZVIZ with Nelly
Sent the RCA back for an EZVIZ and put LaView 190625 build on it. Working great in the app but I haven’t used blue iris in years and only played around with it a short period back then anyways. I’m really not sure if Onvif is working or not but I see the image.
Thank you, I added it to the Chime Compatibility list in the 101.FYI, the Friedland D3126 is compatible.
But you need to change the power adapter. The one provided is too weak.
You also need to only use the left pins.
I have placed a WARNING in the 101 for RCA Owners...I got mine yesterday, installed it today and apparently bricked it two hours later.Tried to install the Nelly's FW using Batch Config...said successful, then the DB went offline after reboot (I figured the FW wiped the wifi info since it never came back). Went outside; red ring around the db now. Pulled power for an hour (red ring died). Applied power and red ring instantly comes on. I tried the reset button (figured I had nothing to lose), but it doesn't function. Tomorrow I will try to put the RCA firmware on SD to see if that works...any other suggestions would be appreciated.
Something is happening, I just found a third person that posted the same thing, all are new RCA owners. We did not hear back from acmonster but rkulp89 sent back his RCA.Best to remove the doorbell and take it inside and connect it to a spare transformer. Easier to work with this way.
Try maybe holding the reset button down while power up the device.
Wondering if RCA is locking the device to only utilizing their firmware?
Whatever you do don't let your Return time period pass. So far from my search, No One (2 other RCA Owners in this Thread) has gotten past the Solid Red Ring issue. If you do fix, please keep notes to what measures you took so we can help others. Thank You.I got mine yesterday, installed it today and apparently bricked it two hours later.Tried to install the Nelly's FW using Batch Config...said successful, then the DB went offline after reboot (I figured the FW wiped the wifi info since it never came back). Went outside; red ring around the db now. Pulled power for an hour (red ring died). Applied power and red ring instantly comes on. I tried the reset button (figured I had nothing to lose), but it doesn't function. Tomorrow I will try to put the RCA firmware on SD to see if that works...any other suggestions would be appreciated.
