Time: Feb 05 11:21:18
IP: 192.168.0.225
Host:
Facility: local6
Priority: info
Tag:
Message: Feb 05 11:21:12 192.168.0.225 "Storage.HotPlug" { "Action" : "Add", "BUS" : "MMC", "Device" : "\/dev\/mmc0", "LogicNo" : -1, "Media" : "FLASH", "PhysicNo" : 0 }
right now i haven't get any REPORT for this. This happen when you do the updating?OK the Toshiba card completed the h2testw test with no errors reported.
I've put the card back into the camera and it is not being listed at all under the Settings - Storage - Destination - Local section so I can only assume either the camera magically failed at the time of the upgrade or there is an issue with the latest firmware.
Is anyone here successfully running a microSD card with firmware 16.R or this release (18.R) please?
@EMPIRETECANDY are you aware of any problems with this firmware and microSD storage please?
I've enabled syslog and saw the following event logged which I assume is related.
Code:Time: Feb 05 11:21:18 IP: 192.168.0.225 Host: Facility: local6 Priority: info Tag: Message: Feb 05 11:21:12 192.168.0.225 "Storage.HotPlug" { "Action" : "Add", "BUS" : "MMC", "Device" : "\/dev\/mmc0", "LogicNo" : -1, "Media" : "FLASH", "PhysicNo" : 0 }
I do not see these Storage.Hotplug events on the 5231 which does not have a microSD installed.
I would try a different brand of card, like a Samsung or SanDisk. You may have run into a compatibility issue with what types of memory or maybe the controller that is used in the Toshiba card. Just a thought.OK I've done a full factory reset and still no joy - the microSD card isn't detected.
Is anyone here running this firmware with a microSD card successfully please?
I had SD card issues with this firmware but I was coming from an hikvision camera. I put it in a Mac and formatted to exfat and now it is detected with this firmware version.
It's certainly strange as that same card has worked fine in this camera 24/7 since January 2017.I would try a different brand of card, like a Samsung or SanDisk. You may have run into a compatibility issue with what types of memory or maybe the controller that is used in the Toshiba card. Just a thought.
