Iemand91
Getting comfortable
Yes.So you mean everything is working as before and working fine on Pale Moon v27?
Yes.
The water mark is imbedded in the file, not displayed on the screen normally. It's to prove that the file has not been tampered with.Andy,
With the IPC-HDW5231R-ZE I just got from you. This new firmware does not seem to control the watermark. I don't see the watermark on the screen in the cameras GUI at all. Or am I doing something wrong? Below is default setting after flashing.
I see it on a hardwired connection with a new IPC-T5442TM-AS. Looks like I don't want to "upgrade" my 5231s right now. On the camera's web UI the main stream stays up for about a minute before switching to substream. Viewing the mainstream on smartPSS via the NVR is solid, which would seem to me to eliminate any network throughput issues.FWIW, i've only see the switching to sub stream "for better video experience" when my connection is bandwidth limited. are you all seeing this on a hardwired connection ?
I've found that setting the iFrame to equal the frame rate, stops this behavior.I see it on a hardwired connection with a new IPC-T5442TM-AS. Looks like I don't want to "upgrade" my 5231s right now. On the camera's web UI the main stream stays up for about a minute before switching to substream. Viewing the mainstream on smartPSS via the NVR is solid, which would seem to me to eliminate any network throughput issues.
I'm running 10 for both settings. Maybe there's some magic combination of settings that helps, or browser type and version. This issue isn't significant to me because I rarely use the camera UI for viewing. My big issue is IVS not working very well with the 5442, but this is the wrong thread for me to whine about that.I've found that setting the iFrame to equal the frame rate, stops this behavior.
I can't duplicate that on mine, I have https enabled and running V2.800.0000014.0.R.191203, I get a login prompt when going to that URL. I can login and then refresh and it brings up the snapshot as expected.This firmware allow me to bypass without any password even when i have password setup
last isLooking to confirm that this firmware is correct for my IPC-HDW5431R-ZE camera. Currently I am on 2.622.0000000.31.R, Build Date: 2018-08-13. I notice this firmware seems to be correct for my camera (purchased from Andy), but given the change from 622 to 800, I would like confirmation if anyone can provide it. I do not see mention of this particular model number in the thread, but the OP does include IPC-HFW5XXX-ZE.
Call me overly cautious, but I messed this up a few years ago, and the recovery was painful.
Thank you!
| DH_IPC-HX5X3X-HDMI-Rhea_Eng_P_Stream3_V2.622.0000000.31.R.180813.zip |
full list cams Hx5x3x-Rhea багатомовна прошивка IP відеокамер Dahua за 02.12.2019Looking to confirm that this firmware is correct for my IPC-HDW5431R-ZE camera. Currently I am on 2.622.0000000.31.R, Build Date: 2018-08-13. I notice this firmware seems to be correct for my camera (purchased from Andy), but given the change from 622 to 800, I would like confirmation if anyone can provide it. I do not see mention of this particular model number in the thread, but the OP does include IPC-HFW5XXX-ZE.
Thank you!
Where am I looking for these logos? on the physical camera? On the camera login?General one is without dahua logo
DH one is with dahua logo.
Default or Factory Default? They are two options in the Setting>System>DefaultPlease make a default after make the update, a
Logo:Where am I looking for these logos? on the physical camera? On the camera login?
curious do you have a full window shot of the older firmware or both? Your window shots here are cropped pretty small.I have applied the "Build Date: 2019-12-02" version, but I miss the 'set interval' in the smtp options. I used this option to get only one email with a snapshot when a tripwire has been triggered. Now I get mutiple images when a tripwire is triggered.
Does anyone have the same issue and know how to resolve this?
old firmware:
new firmware:
Do you mean the whole smtp settings page, like this:curious do you have a full window shot of the older firmware or both? Your window shots here are cropped pretty small.
Does this mean "set the camera to defaults," as in Setting -> System -> Default -> Default, described as "Other configurations will be recovered to default except network IP address, user management and so on."?Please make a default after make the update, ...
"Other configurations will be recovered to default except network IP address, user management and so on." I read that as: Essentially everything except what's needed to access it again.But does that reset your video settings, like zoom, WDR, 3D NR etc?
