Damn that’s a pretty good deal. Did you contract out yourself?
Generac 24kw is costing me $12k for everything. Plumber is coming out today to finish plumbing it up. I had my house gas pressure increased from 1/4 psi (7” W.C.) to 2 psi so I had to also put appliances regulators on my gas grill, stove, and hot water heater. At least now the Gen won’t be starved for fuel with a 2psi system. Also gives me headroom to move to a tankless water heater later this year.
Yes, and I built the pad.
$36 low pressure gauge to make sure unit not starved for pressure
$141 4x4 treated and screws
$45 gravel
$861 plumber
$1908 electrician
$3822 genset w/ xfer switch
$131 battery
$6945 subtotal
Paid for most of the unit w/ home depot gift cards... amex points.
Plumber tapped into gas line, added a 't' for gauge, and ran to unit.
Electrician installed xfer switch, new load box, moved ALL circuits over, did initial crank/run cycle, and submitted warranty paperwork. He was kohler certified so I got 2x warranty if he did initial cranking.
Re: 14kw unit. This thing fires off my 4 ton a/c w/o breaking a sweat. It easily runs the a/c, stoves, cooktop eyes, dryers, 120v appliances, etc. Only real limitation is that you can't go "crazy"... the dryers are 7200watts each.... so if you have clothes drying I can only use one unit at a time.
Anything much over 14kw would require gas pressure upgrade, which I did NOT have to do.
Longest outage so far was 30 hours in summer of 2021.
As far as air versus water... I'd go air every time. Less cost, complexity, maintenance, etc. Generator engines, unless you have a block AND coolant heater are subjected to a ROUGH life. They are cranked and put under full load within 3-5 seconds typically. They are NOT going to last for 5-10k hours. And unless your power is HORRIBLE, you won't need it to. This unit is just under 8 years old and has 197 hours on it.
