alekk
Getting comfortable
The latest new Smart IR firmware has been updated to the website for downloading now. It's for S3 version use only. smart IR is working amazing with this latest new fw, so highly recommend to update.
empiretech01.com/pages/download-firmwares
So "Santa" (aka Andy!) just delivered a IPC-T54IR-ZE-S3 today. I've been futzing with security cams for a couple of decades - most recently the Hikvision world. So I'm fairly familiar with the concepts and the menu's are (not surprisingly) very similar.
Under System->Update, it says System Version 3.100.000000.5.R with Build Date of 2023-05-09. If I run a Manual Check, it says I'm using the latest version. So I'm assuming (similar to Hikvision), I just download the .bin files from Andy's link (for the ZE-S3!) and apply them - right? And per "UpdateAttention.txt", I first apply Firmware.bin and then the Empiretech IPC-HX5XXX (long name) .bin file - right?
I just want to make sure I don't BRICK this on my first day! ;-)
Also, is there any API documentation available?
I'm specifically interesting in being able to pull a snapshot image via a remote wget/curl command?
Thanks!
