Promod117
- Mar 10, 2014
- 213
- 29
In some cases you maybe present with Chinese menu, so you will need to cycle through options until you find out how to change it to English language.
When someone finds out, please post!
There is a video someone made in this forum how to use preset 95, try searching for it. You simply call the Preset 95 like you would call any preset and use your arrow keys. In some cases you maybe present with Chinese menu, so you will need to cycle through options until you find out how to change it to English language.
Ok found it I think
It blue arrow in the preset 95, when I clicked on it then a menu appears in the camera viewer correct?
Resetting the camera now then I'll try the sensitivity
Bill
Which arrow do you use to get to the English menu?So I find that 4x firmware in terms of night/IR performance has been problematic and surprisingly worse then my 3x camera. You have to play with adjustments using preset 95 and even that doesn't get you ideal results...
Mine came as English. But if you arrow down 1 from info to camera, then right arrow the first choice is language.
I was referring to Preset 95. When I call it, it is a Chinese Menu. The rest of the UI is in English.
Oh! I'll have to try that tonight. Thanks!Yes that is what I was referring to. When you bring up preset 95 then arrow down 1 from info to camera, then right arrow the first choice is language.
The main flaw with my 4x is night vision is terrible and focus issue at wide angle
