mlandau33
Wittaj: Thank you for the very complete advice. I will try this
Hey all, I’m new here but just wanted to chime in. I have almost the exact same issue .. the fix was as described here.I guess worse case is you could pull the camera off the NVR and use a POE switch or POE injector or 12V power supply to hook it up to a computer and make the changes and then hook back up.
It is odd that you can see the video stream but not access the camera though.
Wittaj: Thanks. I was able to get to the camera GUIs for my three Lorex cams, but for Andy's cam I get the error message, "site can't be reached." Any idea why? I was thinking that it might have to do with the Lorex firmware for the NVR having trouble with Andy's camera.
Oh, and the nighttime picture/video on the three Lorex cameras have improved a lot based on your recommendations, but I will spend more time with those on another night.
Here goes: 4MP Ultra Low Light Starlight+ IR Turret AI Fixed-focal IP Camera IPC-T5442TM-AS - IP Cam Talk Store
On Amazon:
Both listings are from Empire-tech Andy.
Thank you , were you able to get it to work with your Lorex NVR? Also, was it basically plug and play? Lastly, did the features of the Lorex app work with these cameras?
