tommy20020
Thanks for quick reply, will try one more time over the weekend.
I only use HIK firmware, I've yet to try a Laview FW. I believe the current latest version on Laview site is 5.40. I can't speak on those FW's. What I will say is make sure you use the TFTP method to update, it works when other ways fail. To use, make sure IPC is on, then start tftp program, make sure ip address shown in program shows 192.0.0.128, not 127.0.0.1. when ip shows 192.0.0.128, then restart IPC. TFTP should pick up IPC from that point and start the FW update. After update it may reboot IPC and reflash FW again, so make sure you stop the tftp program after it says completed, and never during a flash process. Personally, I let it run through a couple of times before I stop it. Good luck!
