just because you measure 12V there doesn't ncessarily mean it can supply any current at that voltage... Feel free to try it, but it might either not work (can't supply the current) or blow something up...
Dahua camera mod to power external IR lightI'm re-considering my idea of using the 12 V input connector on a camera as a 12 V output. Has anyone tried this?
I've modified several different Dahua model cameras to power an external IR illuminator. At least a few of the POE supply components are the same in every one I've looked at. The first component connected to the 12 volt power input is a diode to prevent 12 volt power from going out of the camera. All it takes to supply the connector with 12 volts from the camera is to bridge this diode. Every time I do this I first warn my wife that I might be destroying a perfectly good camera. Here's a picture of the mod for an IPC-T5442T-ZE:
Sorry if I sound like a broken record, don't do it if you're not willing to risk bricking the camera.
The dahua cameras have another hint I don't see here, a "+" screened on the circuit board next to the diode that needs to be bridged.
You want to check for a direct connection from the center pin of the 12 volt input to one of the diodes.
For the 4-watters, the IR-40 and AI4 are the only two that are worth using IMO. From the picture above it looks like your FOV is fairly narrow so maybe a single illuminator will do. I get the best coverage using two of them with the hotspots distributed, but my cameras won't drive two 4-watters. I use a POE splitter when powering two illuminators. There are male-male power adapters available if you want to reduce the wire mess from the spitter cable. In a few cases I point the illuminator a bit upward so it doesn't light up the ground so much. The camera compensates for this and makes everything else darker.
. And I can't return them because they've all been surgically altered for focus or for power.
Component-wise I've found no difference between turret vs. bullet. Each model has been different physically and in general working with the varifocals is more complex. I've bought the IR-40s from the cmvision web site or their ebay store and they've shipped from the USA, Houston I think. Browsing their web site today reminds me that my recommendation is for only this one model. I had tried cmvision's IR3 and IR4, and neither one lasted more than a couple of months.I saw that you applied this mod to a turret/eyeball camera as well. Anything different when working on this form factor?
They arrived yesterday, 4 days after order placement. I connected one last night, but didn't mount it high up, and I caught my first coyote on this "downhill" camera. Seems to work fine with my diode-bypassed camera, and the mounting is both simpler and more flexible than that of my clunky 6W illuminator, because it allows for 2 axes of rotation.Thanks! I ordered a pair of the IR-40 units and some male/male adapter cables. The illuminators won't arrive from China for another week or two.
I'll try angling my existing illuminator upward a tad, but I might leave it where it is, too. Sometimes the coyote is very near the camera, and I want to be sure he's well lit-up. I've been saying "he" for the last few months without actually knowing, but now we know![]()
Amazon had these in stock, so I ordered yesterday and got it today! Disassembly on these is actually easier than on the bullet, because there are fewer pieces. Which probably explains the $8 price difference.I'm thinking about replacing at least one of them with what appears to be the equivalent eyeball, the IP5M-T1179EW-28MM, which has all the same specs, plus audio, for $8 less
But I need to bypass the 12 V power diode on that one, too, if I'm going to use it as a replacement.
