Can you please also post the firmware update for the old version of the same camera , the name of the camera is the same (see post #25)There has some newer update for this firmware, check the 1st page.
Same here. Apparently we need the file for the older firmware, only available by a DM. No direct link that I can find.Unable to update two IPC-T2431T-AS, hangs when uploading firmware file.
Please (see also post 16)Can you please also post the firmware update for the old version of the same camera , the name of the camera is the same (see post #25)
The first file (General_IPC-HX2XXX-Molec_MultiLang_PN_V2.820.0000000.33.R.210705.bin) hangs at "Transmitting files..., please don't leave this page or close the browser..."Watch on the 1st page I post the other firmware on it, General_IPC-HX25(8)XX-Molec_MultiLang_PN_V2.820.0000000.33.R.210705.bin
Use the configtool to finish the upgrading.The first file (General_IPC-HX2XXX-Molec_MultiLang_PN_V2.820.0000000.33.R.210705.bin) hangs at "Transmitting files..., please don't leave this page or close the browser..."
This file (General_IPC-HX25(8)XX-Molec_MultiLang_PN_V2.820.0000000.33.R.210705.bin) finishes transmitting but results in "Update package invalid and update failed. Device will reboot immediately."
Any Suggestions?
System VersionV2.800.0000000.16.R, Build Date: 2020-04-18
WEB VersionV3.2.1.880675
ONVIF Version19.06(V2.6.1.845551)
S/N6G20B07DN2E1439
Security Baseline VersionV2.1
S/N6G20B07DN2E1441
I tried the file via web browser and configtool software and both fail.
When using configtool I get the message 'wait for try'.
When using web browser it gets stuck on transmitting files.
Have been able to upgrade other model cameras with no issues, seems this specific model sold by Andy might be problematic?
Specs of my two IPC-T2431T-AS
Code:System VersionV2.800.0000000.16.R, Build Date: 2020-04-18 WEB VersionV3.2.1.880675 ONVIF Version19.06(V2.6.1.845551) S/N6G20B07DN2E1439 Security Baseline VersionV2.1
Code:System VersionV2.800.0000000.16.R, Build Date: 2020-04-18 WEB VersionV3.2.1.880675 ONVIF Version19.06(V2.6.1.845551) S/N6G20B07DN2E1441 Security Baseline VersionV2.1
