No, change the actual size of the image on the screen. Make it bigger or smaller.
Like in multi-cam view, the jagged may show, but not in full-screen, or vice versa.
And yes these cameras need a higher bitrate, but if the jagged lines bother someone too much, they may have to lower the bitrate to soften it more if dropping the sharpness results in too much soft.
Ok you’re talking about manually messing with the original size of the image. Blowing it up beyond 100%. Sure I get that. Just like digital zoom on video, same thing, I’m stretching pixels beyond what they were recorded at.
When I post an image it’s native. When you click on it to see it separate from the post it’s still native. But I can keep clicking or on a iphone spreading with two fingers, and make it physically bigger, distorting it past its original resolution, it goes to shit.
On his image with the white vehicle, the image is jagged at what should be native size. There’s something else going on there. The original image at 100% should not have that severe jagged edges
And as I noted, his .png is showing a far less than normal resolution and file size. I’m guessing it’s a substream export and not mainstream. Maybe from a phone?
@Olddawg how did you grab/export that image?
