Are these cameras the same other than the form factor? The turret is considerably smaller than the bullet version. I'm installing these on a new house and I'm concerned about the large size of the bullets. Any advice is much appreciated.
I cant find the model you mentioned anywhere. IPC-B541R-ZE S3I am trying to buy the IPC-B541R-ZE S3 version, but Andy appears to be out of them,
Thank you for your responseIt should be the same unless you bought it from someone with old stock.
You will be able to tell by the GUI - if it is the white/blue, it is the S3 version.
Those are still good, next time when you buy new cams(Any model) we do some discount for you. Just contact me. Amazon still not have the S3, we just get 6 to try.I just installed nine of the non-S3 bullet cams that I purchased on Amazon one week ago. Is there anything I can do at this point?
Oh I thought you said mid June.For the review just refer to the IPC-T54IR-ZE S3, they are the samething.
New one support build in mic, aucpick and have some improvement on pics, esp at night
They are ready at our website, can buy now
EmpireTech IPC-B54IR-ZE-S3 1/1.8" CMOS 4MP IR 2.7mm–12mm Vari-focal Bu
4-MP 1/1.8" CMOS image sensor | Built-in IR LED | The max. illumination distance is 60 m | IVS | Face detection | People counting | IP67 and IK10 protection | ePoE | SMD 3.0empiretech01.com
Thanks!No need to wait, but not too many just have 2 now, and can ship out anytime.
You are a god amongst us all!Are you happy with the performance of the cameras you have?
The 5442 non-S3 cameras are still incredible cameras.
The 5442 is the gold standard and while the S3 is the newer version, many are not out replacing the older 5442 with the newer 5442.
I have several of my 5442 older cams doing "mission critical" type viewing and decided not to swap them out with the newer S3 models I have.
And my 5442s are original versions from 2018/2019, whereas the one you bought is newer.
The S# simply means different chipsets, so your 5442 would be newer and better than my original 5442 series.
