If you have profiles set up based on time, then yes. I have a day and a night profile, and I tell it which one to run based on the profile.
ah, I was wondering in what scenario I would use profiles.
seeAwesome work!
I did a bit of research and couldn't find much on this, so if one were running DeepStack in Docker, how would you point DS to this community model?
I'm assuming I'd have to copy the .pt to the Docker host, then add an env variable for it?
docs.deepstack.cc
Sorry, I should have clarified further.see
and for the BlueIris config see the first pages of this thread, but I found a problem with that (a couple of posts back)Deploying Your Model With DeepStack
docs.deepstack.cc
I am hoping to issue a new combined, general, and animal by Friday. Hopefully the next version will have better results.
In first postWhere do I get these custom models?
YesCan anyone use these models?
At this time I am taking a break on this project, I will resume shortly. I have been working on the below ALPR project.Can I contribute to this project?
Thanks for the quick reply! So I've been having issues with high CPU usage when DeepStack is analyzing. I hear of people having dozens of cameras on equipment that's a lot older than mine and they have like 500ms process times. I only have 2 - 5MP Amcrest cameras running 15 fps with substream and have done all of the optimizations recommended in the forum. As soon as the camera is triggered my CPU goes straight up to 100% utilization. I have a Core i7-11700k processor so that should not be the issue but I can't think of what else would be causing so much usage. Do you have any tips?In first post
IP Cam Talk Custom Community DeepStack Model
I figured out how to download the images that DeepStack used to train the object model. With these images I can start to make the community custom DeepStack model, below are the steps to create the custom model. The first step would be to create a new DeepStack custom model using the same image...ipcamtalk.com
Yes
Blue Iris and DeepStack ALPR
I took a break from my DeepStack Custom Model project and started work on a DeepStackALPR solution. I made a lot of progress on the DeepStackALPR. The solution is API that crops and rotates (if needed) the license plate. Then the API reads all of the characters in the plate and logs the license...ipcamtalk.com
Post a screenshot of one of the camera's AI settings and the main AI settings. Are you using the custom models in the first post?Thanks for the quick reply! So I've been having issues with high CPU usage when DeepStack is analyzing. I hear of people having dozens of cameras on equipment that's a lot older than mine and they have like 500ms process times. I only have 2 - 5MP Amcrest cameras running 15 fps with substream and have done all of the optimizations recommended in the forum. As soon as the camera is triggered my CPU goes straight up to 100% utilization. I have a Core i7-11700k processor so that should not be the issue but I can't think of what else would be causing so much usage. Do you have any tips?
I am using the GPU version of DeepStack. If you have a Nvidia GPU then you should use the GPU version, that will increase detection times and reduce CPU utilization.Which version of DeepStack did you install? Did you use the GPU version?
I'll send screenshots when I get to my computer. I am using the CPU version. I did just buy an RTX 2060 graphics card in hopes to get that usage down. I've heard great things about it so fingers crossed. And I am using the "combined" custom model.Which version of DeepStack did you install? Did you use the GPU version? If you do not have an Nvidia GPU, you may see CPU spikes.
With the RTX 2060 you will see 100ms +-25ms and no impact to your CPU.I'll send screenshots when I get to my computer. I am using the CPU version. I did just buy an RTX 2060 graphics card in hopes to get that usage down. I've heard great things about it so fingers crossed. And I am using the "combined" custom model.
That sounds perfect to me. I'll currently get 6000ms+ times way too frequently and I can't figure out why. Like I said, I'll send screenshots when I'm home and am just hoping that I have some settings wrong. Thanks for the feedback.With the RTX 2060 you will see 100ms +-25ms and no impact to your CPU.
Here are the screenshots of my camera's settings. I've tried using only 5 real-time images at 1-second intervals and I got the same results.With the RTX 2060 you will see 100ms +-25ms and no impact to your CPU.
I missed that, good pointI'd cut the number of images used down to maybe 10. 999 is really high
Even when I just had 5 images, 1 per second my CPU went up to 100% immediately. Nothing seems to keep my CPU usage to a reasonable level.I'd cut the number of images used down to maybe 10. 999 is really high and will keep the CPU churning for the full length of a clip, at 999 with a 500ms timing that means 45.5 seconds worth for a trigger.
Did you install the RTX 2060 yet?Even when I just had 5 images, 1 per second my CPU went up to 100% immediately. Nothing seems to keep my CPU usage to a reasonable level.
I JUST ordered it yesterday so I should see it before the weekend. I'm still getting all of my necessary alerts, it's just taking a lot more of out my CPU than I expected. Just recently I got an 8654ms process time...I've attached a screenshot for referance.Did you install the RTX 2060 yet?
